Brake caliper sliders - lubricating
What's the best/usual grease to use for brake caliper sliders, in particular the Ford Sierra rear calipers ?  I did a search and nothing came up.
Thanks, Steve
I've got my brackets minus slider bolt in a carrier bag under my desk ready to get them blasted. When I put them back together (if I don't get brakets/sliders included with recon calipers) I was just going to use normal grease. I don't think they move much at all so I doubt anything else would be necessary.
That's all I'm going to do, I may be wrong tho'
The tricky bit will be getting the rubber sleeve back over the rusted 'lip' on the slider bolt. Hopefully it will stay in place.
cheers
Mike
Thanks Mike, I've just got recon calipers from Brakes International and they came without the slider but with new seals.
Ah, right. I was going to give them a call to see what was included. You've just answered my question.
How much were they and do they look ok?
thanks
Mike
Use copper slip as on the other brake moving parts.
Ordinary grease is not high enough in temperature rating and will turn to oil when the brakes heat up!!!
Thanks paul, good point !
Mike, they look good, gold colour, they were £48+£30 surcharge+vat.  Arrived next day.  They also have a scheme where you pay an extra £6 and they'll arrange to collect your exchange calipers.  I'll post some more detail when i get home.  Quite cheap compared to the rest.
Steve
Not much to add really, box says hard chromed piston.  Made by Budweg.  Looks very similar to the original Ford caliper  ;)
Silicon grease (white) is what to use. Don't use copperslip cos it will go hard after a time and will cause the sliders to stick.
Ding to what Windy said! Copper grease is there to stop things seizing, not to keep things moving (a subtle but very important difference...)
I just got my brakes from Brakes International.
Gotta say they look good, but I've realised that they don't have those long long wierd bolts,shown here http://www.n-hatton.demon.co.uk/Westie....led.jpg
Where do I get them from and how much are they gonna cost me??
If I'd have known I would have removed them from the exchange pair before I sent them back.
:durr:  :arse:  :durr:  ???  :arse:  :durr:
DC
Oh, that's a bummer David. You 'may' be able to get them from your local Ford dealer. I asked my local and when we found them in the system I think he said they weren't available (or maybe just not at that time). You may end up having to get another pair from a scrappy ???  :(
But someone must supply them somewhere, if you find out give us a shout.
Maybe just give Brakes Int. a call and explain or maybe they can supply new ones + the dirt seals that go with them.
Mike
Well the calipers have come with the seals but not the bolts.
I've emailed them, and will phone tomorrow (the brakes only turned up at 7 o'clock tonight, apparently they got delivered to the neighbours).
Hopefully they'll put the ones from my exchange pair in a jiffy bag and post'm back to me.
Oh well
DC
