removing rear wishbones
Have recently bought a 1990SEiW.   :D  :D  :D  :love:
I'm looking to remove the (rusty) rear wishbones to get them re- powdercoated. Not a problem apart from the fact that I can't seem to be able to get anything on to the nut at the lower forward mounting to lock it in place :durr:  :arse:
Any help or suggestions gratefully recieved :sheep:  :sheep:
If yours is built like mine (and no two seem the same ;)), when you remove the seats, you'll find a rubber plug (about 2" diameter) near the floor / near the tunnel.  Removing it gives access to the front mount of the lower A-arm.  You'll also want that access for alignment as well as tightening when you reassemble.
Enjoy.  :xmas:
Aaaahhhhhhhh!!!!  :blush:  :blush:  :0  :D  :sheep:
That makes a lot more sense :durr:  :durr:
Thanks :D  :D  :cool:
