Detachable arches
I will be fitting rear arches to body tub this week and from various build sites have seen two methods,
1.Clamp to body and drill all holes
2.Drill arch, then clamp and drill holes
The advantage of 2 seems to be that I can drill the arch from the join side first. Is this any easier?
Also on one site I read that having fitted the arches it was then necessary to remove them when fitting tub to chassis, to allow the tub to flex.  Is this recommended?
Apologies if these are in the trivial league, but having now collected my shiny crimson fibreglass I don't want to damage it. ???
TIA
Rick
I fitted mine after the body was on the chassis and clamped them in place and drill thru both together - it's the best way to get the holes to line up.
Neil  :cool:
I clamped the arches to the body and drilled through both flanges in one go. This worked very well for me.
I do NOT recommend removing the arches, fitting the tub to the chassis and then re-fitting the arches. Some people do this as it makes it easier to pull the rear of the tub up onto the bottom mounting brackets but as the tub flexes whilst doing this, I reckon that you want the tub and the arches (attached) to 'flex' together and keep the join line correct ....
Just a thought - I've seen rear arches involved in "incidents" from time to time.
Those fixed with steel bolts not only damaged the arch when crunched but also damaged the bodywork flange where attached.
Arches secured with "plastic" fixings caused much less damage to main body tub  ;)  as when crunched the plastic fixings simply sheared off leaving a mangled arch. But main body tub less damaged and simply able to receive a new arch   ;)  :D  :)
Arches secured with "plastic" fixings caused much less damage to main body tub    as when crunched the plastic fixings simply sheared off leaving a mangled arch. But main body tub less damaged and simply able to receive a new arch
I like this idea ....... can you still stand a pint of bitter on the arch without it falling off though?
:devil:  ;)  :D  :)  ain't you got enough room on top of the boot box lid  :D
i held mine on with number plastic number plate nuts and bolts. the idea being that in case of  an accident it hopefully wont take the tub with it.
no problems yet. if they do start to come free i can always fit steel bolts.
Having just the black vinyl cover type of boot 'lid', this doesn't work too well as a table  :arse:
Thanks for the replies.  :)
Rick
thanks very much mr stanton! good point on plastic fixings! :D
Now why couldnt i have read this before i put my car together!!!
Bought detatchable arches in case of an incident with the arches.....trouble is, arches are a #### sight stronger than the body tub!
So now my arches are fine, but my body is split....b*ll*x!
What kind of plastic fixings did you use? Nice idea as long as they last well enough and do not fatigue.
Incidentally, I drilled all holes connecting the arches to the wheels separately.  First of all I drilled the tub, then I clamped on the arches, marked the arches and drilled them separately.
I did it this way because I have a big one ( drill that is and it is a bit unwieldly ).  I fitted the arches and tub together and put on the chassis as one.  No Problem at all.
Having just fitted the arches, I find there are 3 bolt positionsthat my drill won't reach.  I followed the "clamp and drill" route, so I guess I will have to unbolt and drill arch and tub separately for these.  Unless any one can suggest an easier way?  Is there such a thing as a 90 degree adaptor for my drill chuck?
Just one observation, the offside arch required a lot of work on the locating blocks to get a good fit, the nearside hardly needed any.  Presume this is GRP tolerances at work?
Rick
