MT75 or Type 9
I was just reading a post on here and someone mentioned that if you have a VX engine you can't have an MT75 box and has to be Type 9, is this true?
I assumed my car had an MT75, what is a simple way to check?
Cheers for your help
Type 9 is slim (about 9" wide just after the bellhousing - hmmm wonder if that's how it was named) MT75 is a fair bit bigger but not sure by how much...... there is a website with pics of them but can't remember where...Dave Andrews site maybe
:durr:
Select reverse. If it's alongside first, and you have to press the lever downwards (towards the floor) to engage the gate, it's a type 9. If selecting reverse means lifting a collar on the gear lever, and slotting it into where 6th gear would be (ie, south of 5th, IYSWIM) then it's an MT75........
....is it definately a Ford box? The Opel Manta box will fit in as well IIRC.... ???  :0  :)
Careful if it's a manta box. I've got one in a type 9 tunnel and it's as tight as a midges t**t!!
That sounds good then, its a push down and next to first, meaning its a type-9 right?
Does that mean that I can get the ratio's changed in it?
Adam
Yep, multitude of ratios available...straight cut or helical as well as dogs etc give Phil Stewart at R&RT a ring for details
  • 2 weeks later...
Anyone got a number or email address for Phil at R&RT then, or any ideas how much changing the ratios is likely to cost?
01959 525105 wk
07836 333882 mob
