Truly Skint Posted August 14, 2010 Posted August 14, 2010 Completely O/T I know, but has anybody got a source of good bog seats and / or hinges ? Every time I buy a bog seat, fix it onto bog, within 2/3 months, the fixing post is loose and you then slide all over when in the sitting position. Obviously, I don't sit that often (I did say SIT), being a bloke, other than to have a mournful pee whilst drinkin a can occasionally and the missues a**, whilst slightly rotund is not that lardy, so I cant really put it down to unreasonable average use Any helpful suggestions would be appreciated (I have also suggested that she buys a shewee and then wouldn't have to sit that often, but that didn't go down too well ) Mike Quote
Blatman Posted August 14, 2010 Posted August 14, 2010 Threadlock on the screws... And once you've sat down, stop fidgeting... Quote
tex Posted August 14, 2010 Posted August 14, 2010 yea they are pants - iv replaced quite a few. they also corrode pretty bad. depends on the seat - there are some with soft close mechanisms that seem better like the one i have now - seems ok so far Quote
SteveD Posted August 14, 2010 Posted August 14, 2010 loose some weight then chubbs or put a cork up your Quote
Jam Posted August 15, 2010 Posted August 15, 2010 yeah the soft close ones are well sturdy. Got one from wickes 5 years ago and it's still going strong! Quote
matt_c Posted August 15, 2010 Posted August 15, 2010 Mrs C and I had this very conversation this morning. The soft close ones do seem to have much less play in them, one of our toilets has one and it's still holding up as well as it did when I fitted it two years ago. Mrs C bought a new one (not soft close) a few weeks ago and it has started falling apart allready, I had it apart and back together with some loctite 243 this morning. Time will tell how effective this will be. Quote
Paul Hurdsfield - Joint Manchester AO Posted August 15, 2010 Posted August 15, 2010 one of our toilets has one And I thought it was gonna be one of those "I've got more bogs than you" thread Quote
matt_c Posted August 15, 2010 Posted August 15, 2010 one of our toilets has one And I thought it was gonna be one of those "I've got more bogs than you" thread Sorry, that's not what I meant. Quote
oldman Posted August 15, 2010 Posted August 15, 2010 You can all jest but this is a serious problem!I've known folk t'understeer and skid into sink Quote
RichP Posted August 15, 2010 Posted August 15, 2010 Have a cr*p at work - you get paid for it and you don't wear out those hinges Quote
Paul Hurdsfield - Joint Manchester AO Posted August 16, 2010 Posted August 16, 2010 Then they seize up through lack of use Quote
Tubs Posted August 16, 2010 Posted August 16, 2010 This is a s**t post! Oh, put a lid on it. Tubs Quote
Truly Skint Posted August 16, 2010 Author Posted August 16, 2010 loose some weight then chubbs or put a cork up your Mrs Truly Skint is after your a@@, i've given her your address details for calling her chubbs !! Thank you, for some constructive comments, I'm glad that I am not the only one. Reference soft close, where does one (I try to speak the queens english when speaking about s***e) buy those from other than Wickes where I look and they were all the crap fittings. Thanking in advance for "Number of bogs" survey Mike Quote
pistonbroke Posted August 16, 2010 Posted August 16, 2010 How many craps per seat should you get ? Is there a british standard crap ? Do you keep a log Quote
