:D  sorted:  thanks Guy  :D
  • Replies 38
  • GuyH
    12
  • Kevin Jones
    6
  • barney
    5
  • Terry Everall
    4
New version hot off the press this morning
- 'Add Run File' option added for Chris
- Should now load multiple valid runs from a single file (but still haven't seen any of this data so I did it blind so to speak)
- Option to show speeds in Mph (for Tel and Barney-the-caveman). On the options menu.
This one wont expire at the end of this month either, have extended that a little as it's getting a little more stable.
clicky
Guy, some run files for testing here.
Bit of mixture of single run, double run and even some partial runs.
  • 1 month later...
New version up.
Includes the ability to see and compare speeds at any point on the graph (for Barney). Just right-click
Sorry to those who have asked for things that i've not done yet, time has been short but I will get there in the end.
And thank you for those test data files Kev, appreciated.
clicky
thanks guy,been using it on anglesey runs...works a treat  :t-up:  :t-up:
  • 11 months later...
I have built a shameless rip-off of Guy's idea for use with DTA logging.
It's a small program you drop logfiles on. From that it splits the data into runs automatically and allows you to display various traces on a zoomable graph of what was happening.
I really just built this myself to make it easier to do inter-run analysis, but if anyone is interested in trying it out I am happy to share and tune to others needs. To work the logs must contain some data that allows the calculation of speed. I use wheel sensors so it currently triggers off the 'L U SP', the left undriven wheel sensor, but other methods should be fairly easy to add.
Send me a PM if interested.
Pm sent!
Del
Good stuff :)
Sincerest form of flattery and all that. Reminds me to put a new version up at some point soon.
  • 1 month later...
