Terry, have uploaded a new version that I think solves your problem. You just need to re-install.
Kev, this might be the same problem you had but can't know until i see the data files.
Ta
  • Replies 38
  • GuyH
    12
  • Kevin Jones
    6
  • barney
    5
  • Terry Everall
    4
Working now :love:
That was it, the data loads fine now and picks out the first run of the file.
woks welll here guy on vista.is there a way to change the speed to mph ?from kph
cheers
Barney
Mph eh ? Terry asked the same question.
You olde world types are so fussy.
:p
... the first run of the file.
Do you guys leave the logger running between runs then, and record 2 runs on 1 file ?
Didnt think of that.. will have to alter logic a little if so.
Users..
I don't leave it running guy the power goes off with the engine. Still seems to put all the runs for that date in the same file though.
Mark.
Simple enough to fix. Could someone send me one or two of these files ?
Guy,
I know it does .RUN files but how easy would it be to do other data files?
I have a digidash (as I'm sure many do) and wondered if you could have a quick look at one of my log files to see if it's at all possible to use for this too?
Extension is .DIG but it's only and extension, files can be opened and read with notepad.
I have already tried to rename the files but says "no interesting data found" which is proably true LOL :D
Tiggs
mark the dl1 creates a folder for that date with all that days runs stored in that folder,its easy to open multiple runs (.run files) by using ctl key.
great prog. guy,looking forward to using it in anger at tycroes... :p  :D  :D  :D
ps does your dad do kph then ...?  :p  :D  :D  :D
kev is that because you leave it on inbetween your double drive runs..?
Of course...................it looks faster  ;)
Kind of, I had it setup to auto-start/stop with a delay on the stop, so if the change over is fairly quick we get 1 run file, if not it might be two.
I will get some logs together and send over.
Tried installing this and it says I have to download .net framework version 3.5.
Tried downloading it but its 53MB.
Has anyone else had to do this.
XP computer??
.Net runtime from Microsoft is required, yes.
Anyone not asked to install it already has it (most machines with newer os's have it installed as standard).
