Rab (bombero) Reid Posted August 9, 2010 Posted August 9, 2010 Just wondering what you guys thought about owning/running a Q plate. Wondering what the pros and cons are (if any). Thanking in advance Quote
SteveD Posted August 10, 2010 Posted August 10, 2010 would not worry about it ,it makes no difference imho Quote
peterg Posted August 10, 2010 Posted August 10, 2010 a Q plate is easier at MOT time as it's tested on visible smoke only Quote
Rab (bombero) Reid Posted August 10, 2010 Author Posted August 10, 2010 Thanks guys. I guess my 'prejudice' is simply based on that age old thinking when Q plates were found predominantly on Cat C damaged repaired and the first Jap imports before the DVLA knew what to do with them. I suppose a 'year' plate would also determine that any given Westy was built using all new parts .. Quote
jak Posted August 10, 2010 Posted August 10, 2010 Buy on quality of car and price - as others have said it's easier with a Q plate at MOT time. Quote
XTR2Turbo Posted August 10, 2010 Posted August 10, 2010 A few other considerations that may or may not be relevant to you. Some insurance companies will not cover Q plates but plenty will. I think if a new built car it's value would be slightly less if Q than non Q. After a few years will make less difference You can't put a personal plate on a Q registered vehicle. I understand you can have difficulties exporting a Q plate car to some countries. Quote
simon_davis Posted August 10, 2010 Posted August 10, 2010 I'd support what the others have said... I wasn't sure about getting a Q car, but it's been fine. The last MoT took all of 10 minutes LOL! Easily insured via Adrian Flux and I've got European cover easily as well - certainly had no trouble sailing over to France and then blatting around Germany etc. As I've just lost a shed load of cash on a private numberplate sale, I'm not bothered about sticking my own reg on the car - no more plate 'investments' for me. Regards, Si Quote
jeff oakley Posted August 10, 2010 Posted August 10, 2010 I perfer a Q, it doesn't age the car the MOT is a breeze. Do not assume that a car with a year plate was made with all new parts. It could be resitered on the donor car plate, you can also have two major units reconditioned and still get a new plate as well. It is down to buy the very best car you can for the money and don't fear a Q at all. Quote
Rab (bombero) Reid Posted August 10, 2010 Author Posted August 10, 2010 Thank you all again for the great responses .. I think that I'm moving ever closer to my first Westy purchase Quote
MGF255 Posted August 10, 2010 Posted August 10, 2010 Having a Q plate won`t cause any problems with a specialist kit car insurer as it`s not out of the ordinary - however you may be refused by most insurers if it was something like a ropey old transit van on a Q plate . As long as the build quality is high the value of the car won`t be affected much at all + as already said MOT time is much less hassle as no Cat emission test is needed . It is true tho` that once a Q always a Q as you can`t put a private plate on but imo that`s no big loss on a kit car (I`d rather have it easier at MOT time) . Quote
Cleggy the Spyder Man Posted August 10, 2010 Posted August 10, 2010 if I was buying second hand and had the choice between two very similar cars I would buy the one with the age related plate - so you could argue an age related plate might be slightly easier to sell all things being equal other than that I believe it makes very little difference with a race type kit car although I would think twice about buying a "classic road spec" style 7 on a Q plate in the same way you wouldn't buy a cobra or similar on a Q plate just my opinion don't shoot me Quote
Jenko Posted August 11, 2010 Posted August 11, 2010 I actually think a Q plate is better for the simple reason of not worrying about emissions, and being able to throw what ever engine in you want a NEVER having to worry about.... Unless you want to put a private plate on your car then 'Q' would get my vote.... That said...I would also not recommend buying a car just on the basis of the plate....there are more important things to worry about. Quote
