2008 Westfield SEIW Turbo (2008)
Overview
Westfield SEIW built in 2008 from a factory supplied rolling chasis. Registered in July 2008 on an '08 plate. Since then it has completed just 4,200 miles.
The car is of a very high spec. The turbocharged Vauxhall engine has seen significant investment and can be run at up to 450 Bhp if desired.
I personally run the car at around 1Bar of Boost - which is somewhere around the 300Bhp mark. 2 Bar would give you around 450Bhp.
Engine
JRE supplied Vauxhall 2055cc 16v Turbo (C20 LET)
V-Tuning Ported and Polished Coscast Head
Genuine Garratt T38 Turbo
ARP Rod Bolts
Arrow Rods
Oil Spray Bars for under piston cooling
Z20 LET head gasket
ARP Head Studs
SBD Steel Valves with wasted stem on the inlet
Titanium Valve Caps
Double Valve Springs
C20 XE Inlet Cam
SBD/Kent Vernier pulley
SBD Shallow Sump
6 Pint Electronic Accusump System
Mocal Oil Cooler
Mocal Oil Catch Tank
Jenvey Tapered Throttle Bodies
Jenvey Throttle linkage
SBD Inlet Manifold
SBD Ultra small 55amp 3.2kg Alternator & Mount kit
Nissan Pulsar GTI-R Plenum
PWR Charge Cooler
Pro Alloy Charge Cooler Radiator
Davis Craig 120Ltr / min charge cooler pump
Aquamist Water Injection
Magnecor Ignition Leads
SBD Carbon Spark Plug Cover
Pipercross Viper Induction system
MSD Ignition control
MSD Blaster 2 Ignition coil
SBD 70deg thermostat
Fuel Lab Adjustable Fuel Pressure Regulator
Bosch 600cc Injectors
Apexi AVC-R Boost Control
Bosch 044 Fuel Pump
Bullet Fuel Filter
Autronic SMC Fully Programmable Management
Billet Lightened Flywheel
Helix Paddle Clutch
Tilton Hydraulic Clutch Assembly
Westfield V8 Radiator
Peter G Stainless exhaust manifold
Full Stainless Steel exhaust
RedTop Gel Battery
Newly Rebuil Borg Warner T5 Gearbox
Ford Limited Slip Differential
2 x Charge cooler radiators at rear of car
Yellow Silicone Hoses
AH Fabrication Foam Filled Fuel Tank
Brakes/Suspension
AP Racing 4 Pot Brakes on the front
Golf brake setup at the rear
Standard Westfield adjustable coilovers
Exterior
Westfield FW Bodywork in Yellow
Carbon Mods Aeroscreen
Carbon Mods CSR Front Arches (with mudflaps)
Carbon Mods Rear Arch protectors
Carbon Mods 75mm NACA duct
Clear Front Indicator lenses
M&P Front Headlamps
Hinged, lockable boot
RAC Roll bar with Petty Strut
LED Rear Lamps
15in Team Dynamics Pro Race 1.2
Toyo PXR888 Tyres
SPA Carbon mirrors
BMW side repeaters
Brushed Alluminium raised fuel rig
Interior
Flocked Dash
Stack ST700-SR Dash Display
Renault Clio Indicator Stalk (Controls lights, horn, indicators)
Motosign warning light display
Toggle switches for Accusump and Charge Cooling pump
Apexi AVC-R Boost Control display
Aquamist flow-meter display
2 x flame beater fire extinguishers
JK Composite part carbon seats with yellow/black pads
Factory lowered floor
Momo Gear knob and handbrake handle
Sony 580 Bullet Cam kit
Luke 3in 4 point harnesses
Intercom System
Passenger Map Pocket
Fully carpeted in Black
Sparco motorsport horn
I've more than likely missed some but if there's anything you'd like to know then please just ask.
The bad bits:
The 'Lucky Number 7' decal on the bonnet is there to cover a crack which was made when something heavy fell off a shelf in the garage onto the car.
The exhaust has a dent in it.
I've priced the car to sell at £16,995 - I've spent well into the £40k's getting the car to this spec and I'll be very sorry to see it go.
Also included with the sale is a good spares pack including:
Spare Vauxhall C20LET Head
Spare Chargecooler Rad and Pump
An almost brand new helmet with tinted and clear visors.
Waterproof Cockpit cover
Westfield Weatherproof Jacket
And so much more.
All build documention, manuals and parts instruction sheets have been kept and filed and will be included with the car.
I also have a specially made bypass adaptor that replaces the turbo so the engine can be run Normally Aspirated if required to do so.
This little fella forces sale  :D
Tel: 07071061673
Email: neil@fw500.co.uk
wow............ fab car
Ditto that comment!
If I had the money it would be in my garage!
Good luck with the sale  :t-up:
That little fella has priority!!! good luck to ur sale my inspirator ;)
My god, anyone want to buy mine, iv seen another one I want to buy, cant think where..........  :p  :p  :p
Thanks for the kind comments. I'll miss the car when it's gone that's for sure!
New Telephone Number: 07071 672 853
  • 2 weeks later...
:down:
New owner's a nice chap... may even be a McLaren fan too - I'll check.
Next project's going to have a V8 but maybe not for a year or so - will probably stop by the Exeter show again this year so may catch you there if you're going Barry.
Good luck with the next project Neil ;)
Thanks Aris - Will keep myself up to date with how you're getting on. I'm really  looking forward to seeing yours finished.
Thanks mate :)
