A bit less confident now
Picked up my Megabusa kit today....
Thought of it of a big meccano set until today....
Now think of it as "take two asprin and lie down!!!!"
:zzz:  :zzz:  :zzz:
excellent,just sit and read the manual for a couple of hours first,take a day of get the chocolate digestives in,and  the coffee kit,put a heater on and close the garage door and make a methodical start and everytime you get stuck crack out the biscuits and, make a brew and check tha manual. you will get there in the end,and enjoy it,if you really get stuck post the question on here.were here to help :D  :D  :D  :D  :D  :D
Don't panic Mr Mainwaring - Take deep breaths, count all your bits and sort them out in order together with the build manual  ;)  :D  :)
Keep a bottle of Scotch close by and go for it  ;)  :)
stock up on the chocolate "suggestives" and tea bags have a look, ask lots of questions and then have a brew and think about it! if you take your time you will end up with a good car! :D
My tip would be to read the manual and then decide in what order you need to do things – I started with the panelling :arse:   but should have put the fuel, brake lines and wiring loom in first.
Don’t run the fuel and brake lines under the floor put them in the transmission tunnel. :t-up:
Use stick-o-flex or  panel adhesive / sealant  to stick the panels in place and if you are planning to run the car without internal trim :t-up:  you will need to panel the outside of the cockpit as you can see the floor and rear wheel through the gap in the body work. :arse:  Invest in a good set of drill bits.
Enjoy pulling rivets….
Neil  :cool:
