Dodgy Headlamp Bracket
Hi,
Just found that the left hand hlamp bracket does not fit correctly. It actually seems to be the chassis mounting rather than the bracket itself as the right hand one will not line up on that side either. It fits in Ok, but the hole for the bolt at the wishbone mount is about 1cm out.
Any suggestions. Or is it a case of bending metal...
Jon
This is a recurring theme!!! Just 'slot' the hole in the bse of the bracket until it fits correctly and then undercoat it followed by two coats of matt black applied by brush. This is by far the quickest way to resolve this .....
