Dave Posted December 8, 2002 Posted December 8, 2002 The Muppet that owned my 1991 SEI Wide before me, butchered the lower steering column by drilling out the spline clamp bolts and replacing them with longer bolts and nylock nuts.?? This has in turn "F"ed the upper column and the rack. the racks not a problem but the other parts ? ? Is the lower column a factory part, a modified Group 4 Mk2 escort one? Or from some other car? Where can I get one. ?Is the upper column form an Austin Allegro.Or from some other car? Where can I get one. Ta Dave Quote
markg Posted December 8, 2002 Posted December 8, 2002 get a price from westfield! theyre not too bad! about £62 for lower column dont know about top as it came with kit! Quote
DavidC Posted December 9, 2002 Posted December 9, 2002 Top is £98.81, and the lower column is £62.50 in the latest price list Quote
Neil Purdie Posted December 11, 2002 Posted December 11, 2002 STEERING Track rod ends - Cortina mk3/4/5 - Rack and mountings - Escort Mk2 - Upper steering column and bushes - Escort Mk2 - Connecting shaft ( double jointed ) - Austin Allegro ( modified ) copied from my site, if you have any other info or numbers let me know Neil P Quote
stu999 Posted December 11, 2002 Posted December 11, 2002 Neil, early cars have Escort upper column, later Westfield upper columns are Allegro, again modified by the factory, or alternatively a brand new one is available from the factory. Quote
Neil Purdie Posted December 11, 2002 Posted December 11, 2002 Stu999 Any idea of the year or chassis No for the swap over. I will update my numbers page. Cheers Neil Quote
stu999 Posted December 11, 2002 Posted December 11, 2002 I havent mate sorry. All I can tell you is that there was a discussion some time ago on what steering wheel boss fits the Westfield column. Somebody mentioned that it was an Escort boss required but I went in with both feet knowing full well my mates Westy had an Allegro column just recently modified by the factory. Little did I know my Westy was sat on the drive with an Escort column fitted.... Quick identification seems to be whether the car has a steering lock fitted (Allegro) or not (Escort). I will have a look later to see if I can find the thread. HTH Stu. Quote
stu999 Posted December 11, 2002 Posted December 11, 2002 Found it!!!! Probably wont be of much use though..... Quote
Neil Purdie Posted December 12, 2002 Posted December 12, 2002 STEERING Track rod ends - Cortina mk3/4/5 - Motaquip VTR151 - motorfactors £4.30 ea Steering rack boot kit ( pair )- Motaquip VSG164 - motorfactors £5.00 +VAT Rack and mountings - Escort Mk2 - Upper steering column and bushes ( early cars, without steering lock) - Escort Mk2 - ( later cars, with steering lock ) - Austin Allegro ( modified ) Connecting shaft ( double jointed ) - Austin Allegro ( modified ) Updated for everybodys use Probably wont be of much use though..... The end ? Quote
