owlscastle Posted June 21, 2010 Posted June 21, 2010 Due to that nasty disease, upgradeitus, I will be selling this excellent setup when my new engine is ready. Engine: . SBD Vauxhall XE 2.0l 16v built and maintained by SBD Approx 230BHP . Coscast head . Fuel injection on SBD Throttle Bodies. . MBE ECU & quality loom . Pace dry sump system . Steel rods (revs to 8750) . High compression pistons . Small alternator . Aluminium idler pulleys. . 233mm lightweight flywheel with 7.25” Helix twin plate paddle clutch (friction plates renewed 8 events ago) used retained and photographs. . Geared starter motor . MicroCool oil filter . Aeroquip hoses throughout . Solid engine mounts . SBD exhaust manifold . Only used for sprints and Hillclimbs – never circuit raced or hammered on track days. A complete package that drives beautifully and is well maintained, ask Dave O (Sorry about this Dave!) Not sure of price, about £3500 I would think reasonable ? Also available Quaife 4 speed dog box with alloy bellhousing for above, stick for Westfield. Price around £1100 ? Still in the car for a while yet, so can be tested and inspected. Ritchie
Scottish Bloke Posted June 21, 2010 Posted June 21, 2010 That is one belter of an engine package, can you make sure you don't sell it to anyone in 'F' in the Speed Series please Good luck with whatever your plans are.......they must be worth it
peterg Posted June 21, 2010 Posted June 21, 2010 and there's also a rolling chassis for sale now that this would drop right into and make a cracking car
perksy Posted June 22, 2010 Posted June 22, 2010 Have a similar spec' engine in mine and beleive me 3.5k for that package is very good value for money
John Loudon - Sponsorship Liaison Posted June 23, 2010 Posted June 23, 2010 What are you upto Ritchioe? Does it involve a Puma engine?
owlscastle Posted June 23, 2010 Author Posted June 23, 2010 What are you upto Ritchioe? Does it involve a Puma engine? John, No Puma I am afraid, finally given in to "If you cant beat them join them approach" Need a 2 litre for the mod ltd production class so going duratec.
Bean Posted June 23, 2010 Posted June 23, 2010 Holy s**t that's a great deal, someone lend me £3.5k! This won't hang around long
Spannermonkey2016 Posted June 24, 2010 Posted June 24, 2010 Just out of curiosity what cams is this running ? Cheers Ben
owlscastle Posted June 24, 2010 Author Posted June 24, 2010 Just out of curiosity what cams is this running ? Cheers Ben Cams are whatever comes with the SBD225 kit, hydraulic profile. Ritchie
perksy Posted June 24, 2010 Posted June 24, 2010 Just out of curiosity what cams is this running ? Cheers Ben Cams are whatever comes with the SBD225 kit, hydraulic profile. Ritchie SBD Spec' Cams Inlet has 2.75mm lift TDC & 11.4 mm Max Lift with 284 Deg Duration Exhaust has 2.55mm lift TDC & 11.03mm Max lift with 278 Deg Duration HTH
