Different rivets
I really would appreciate some advice on what all the rivets in the fixing kit are for, I don't want to use the wrong ones.  There appear to be 5 types in the kit
1 Heads about 10mm diameter, 10 mm long
2  Heads 6mm, 10 mm long
3 heads  6mm 15+mm long
4 Blind dome head
5 Blind countersunk head
Or will it be obvious when I start fitting the body??? ???
1 Heads about 10mm diameter, 10 mm long:-
Body tub to chassis
2 Heads 6mm, 10 mm long:-
Aluminium panels to chassis
Sound like 'peel rivets' for general fixing of components to glass fibre
4 Blind dome head
Not sure, need more info.  .....
If they are 'peel rivets' - Press stud bases to glass fibre tub
