Indicator problem
My rear near side indicator has stopped working, I have changed the bulb and thats not it.  Can anyone advise on the next common place to look for a fault as the front one works but flashes quickly.
Bad earth somewhere ?  Can't remember where the rear indicators earth to though, so that's not really very helpful is it...
Certainly an earthing problem.
All mine were taken to a common point on the back of one of the rearlights. (including reverse and fog).
Also check your rear number plate light as this is included in the common earth as well
Clive
Cheers I will check it out tonite and let you know
