Ally panel sealant
Looking for some sealant/adhesive to use when riveting panels to chassis. Any cheap/good solutions that may be found at B+Q or on the net ??
Also, how many tubes (approx) are needed for fixing all the panels to chassis ?
Cheers  :t-up:
Dont use general household sealants from B&Q etc. They give off acidic fumes which will corrode steel and alloy after a time.
Go to an automotive paint supplier (any local car bodyshop will know where the nearest one is) and get some proper automotive silicone sealer.
Use a proper automotive sealant, rather than a bathroom sealant. I believe the anti fungus/ant mould additives in bathroom sealant attack metal/aluminium, so they're to be avoided.
Nice. Two Blatchatters in perfect harmony :0  :0  :)  :)
NF Autos do a suitable sealant/adhesive they advertise in the kit magazines (NF Auto).
I got mine from a local car panel/paint shop. Slightly more difficult to apply in that it's harder to squeeze out of the tube but as a result sticks much better. Usually comes in black. I would get 3 tubes for starters (I presume you've already got a gun).
As it's black you can also use to to seal up any bits where you think the powder coating didn't quite get into.
cheers
Mike
:D  :D
Used unibond black waterproof sealant on my car 7 years ago (bought from B&Q). Having struggled to remove one of the panels during winter rebuild there was no corrosion whatsoever. Seal has obviously lasted (contrary to other people's advice).
Note: The bond is only as strong as the powder coating it is stuck to so if you use the automotive stuff (designed to hold door skins to frames etc) you'll never be able to remove panels again.
Windy
That cant last :0  :D
That cant last
I reckon it will as long as we dont start debating the merits of grass vs astroturf again   :D
Surely no debate - grass is clearly the winner here? Pity about the colour though ......
I think Steppenwolf is dis-agreeing with me just for fun, now...........  :D  :D
Mornin' Stepps.........
Sorry but I just don't agree the above comment ......
Morning Blatman  :)
Nice one stepps.
Have you seen the thread where we started the 'debate'
Morning Cateringvan - no, I didn't see the original thread, I assumed it was on  B L A T C H A T !! I have read it now though   :D
3 tubes of tiger seal will do the trick nicely! its not cheap but it wont drop off! ;)
