:) Just about to drill a 45mm hole in my scuttle  :)
the manual states the hole should be 90mm back from the front of the scuttle and 370mm in from the drivers side.
is this ok as it seems quite close to the chassis on the drivers side.
i will be running a pinto so the loom has to run down the near side trans tunnel. :xmas:
Peter, I did mine as per the manual, also Pinto engined and it's all fitted O.K. I've put my loom down the right side.
