Starter Kit
Any one interested in making an offer before it goes on fleabay?
Thanks for the responses to my previous post.  I've had more time to put a description together, I have phots but don't have the technology get them on here. I can email them if required.
I have a SEiW starter kit supplied in 2005 to the previous owner and I bought it with good intentions about 18 months ago.  I have changed jobs since then and can't fit in the time required to get it built.  So,  I've decided that I need to move it on to a more deserving club member.  As prompted by Simeon should someone want this kit and has a high spec Westfield they are looking to PX I have funds to accomodate the right car.  I can be PM'd/emailed from the site and will call direct if needed for more information etc.
Chassis
Supplied to original buyer in 2005 (Receipts available) Powder coated chassis with aluminium plates fitted to floor, tunnel outer and rear bulkhead.  Aluminium sheets included to complete chassis.   The supply and return fuel lines and brake lines are fitted.
Wide track front whish bones with all fittings attached and a choice of aluminium or Westfield steel hubs if needed.   Rear whish bones fitted with hubs, LSD (3.9) 7” diff and new shafts fitted.  Upper and lower steering columns with keys and quick rack fitted.
Body
The body work is light green and has a V8 bonnet detachable arches and ducted nose cone.  It is stored away from my house and in the loft.  It is what it says on the lid and I don’t have the time at present to get it together for phots.  This will be achieved for an interested buyer.
The other parts I have will be available initially for the buyer of the chassis and body kit only.  I will then re-list the remaining parts for other interested parties to buy.  These parts include:
Light weight brake disks.
Hispec front calipers (set for vented disks but can be reset).
Refurbished rear ford calipers.
AP master cylinder
SBD XE inlet manifold (dressed out slightly to match carbs)
Previously fitted Zetec wiring loom (circa 2002)
Premier wiring loom (new)
Hand brake (used)
Westfield steel fabricated front uprights and hubs (used)
Westfield cast alloy uprights hubs (new)
Front ARB (Westfield) rear ARB (Playscool)
Carbon dash
SVA steering wheel
Westfield 4 point seat belts
Denso alternantor
Carbon effect light pods
Fuel tank and straps (modified for injection pump direct suction)
2.0XE Engine (Ready to build)
Block (bored out and cleaned)
Crank reground and oil seal land repaired
Bearings
Cometic gasket
Omega pistons rings and pins and steel rods
Oil return valve
ARP everything
GM head with porous head modifications, +1mm waisted valves, ported and relieved.
Dizzy blanking disc
QED 420 mech cams and solid lifters.
SBD shallow sump
QED dry sump kit
SBD 208 throttle body kit with manifold
Pico injectors
Oil pump
Water pump
QED lightweight flywheel, helix plate and clutch cover
Cam belt and pulleys
Coscast head
GM head
Most of these parts are new or have had very little use.
The Chassis and Body are the bits I need to move on, the remainder I could use on my current or a future car so as I said above I am open to suggestions/PX.  To put some cards on the table I paid £2800 for the kit and some bits when I bought it and would obviously like to minimise my losses but, I am also a realist and will happily discuss a package of the kit and parts starting at about £2K.
Some phots available if the link works
null
Ivor R
Some Phots added via link.
Know someone who would be extremely interested in the kit and will pass on the spec you list.
Can put him in touch
My e-mail is blackburn1997@sky.com if you can send any pics - the link did not work
Bump for ad edit
Bargain alert  :0  :0 Bargain alert
Thanks Rob, I think so as well.
I
Sold to Paul C,
Many thanks for enquiries.
Ivor R
