Kevin Jones Posted May 20, 2010 Posted May 20, 2010 Been out running on some second hand Avon hillclimb/sprint slicks but suffered big understeer. Managed to dial some of it out with major setup changes but think the real problem was mismatched front/rear tyres for this use, easy to see the rears were much softer then the fronts once they were warm. Will have a chat with BMTR, but given the costs was wondering what I should know before parting with hard earned, such as which of the soft compounds has worked well on mixed sprint & hillclimb work but survived a seasons use of double drivers and opinions on the radials vs crossply slick debate for BEC use. Current wheels are 8" & 10", expecting all in weight is likely to be circa 560kgs (on radials with driver). The Avon codes on the current tyres are 11529 (front) & 8888 (rear). Ta Kev Quote
SteveD Posted May 21, 2010 Posted May 21, 2010 speek to mark anson or barny they run slicks on there bec and are very quick so there the best people to speak to tbh Quote
Kevin Jones Posted May 21, 2010 Author Posted May 21, 2010 Is this with the turbo car ? Yes, should have said, think likely to be running it in the 275-325 bhp range Quote
John Loudon - Sponsorship Liaison Posted May 21, 2010 Posted May 21, 2010 What were the fronts that you used - crossplies or radials? If radials, the front top wishbone geometry looks all wrong from the pic in your avatar Quote
Kevin Jones Posted May 21, 2010 Author Posted May 21, 2010 Good spot, in avatar it's on ACB10s, since then reset geometry for radials. Initially did think it was a combination of bad setup and over driving but when I eventually got around to simply poking the tyres with a small allen key after a run (don't have a durometer yet) the difference front/rear was very obvious. Even after tweaking ARBs, shocks, camber and rake it was bad enough that ACBs would have been preferable in the bends. Quote
barney Posted May 21, 2010 Posted May 21, 2010 the problem you might have is with second hand slicks. how worn are they,there is a mountain of difference in behavior from new,depending on how they were treated,age etc..are they the same compound? cheers Barney Quote
ACW Posted May 21, 2010 Posted May 21, 2010 I never managed to get a season of single driving out of slicks. If I were double driving on slicks I'd be expecting to use 3 sets. However.... I always had one compound that would be a partial compromise between the long fast sprints and the slow short twisty hills / sprints. In an idea world I would have a set of A15 and A40 as well as a set of wets. But no experience of BECs but your power and weight is in CEC territory anyways. Quote
Terry Everall Posted May 21, 2010 Posted May 21, 2010 radials on mine are all A15 compund but what spring rates are you running?and what clicks on shocks Ring me on 07767836234 for a chat Quote
Kevin Jones Posted May 21, 2010 Author Posted May 21, 2010 Fronts are A40, rears A15 but apparently A40s must be at least three years old so rather past there best which ever way you look at it . Tel, running pretty standard mega suspension setup, will give you a call, ta. Quote
barney Posted May 21, 2010 Posted May 21, 2010 3 years old....they will be totally fubar......with no grip at all...try some softner see if they will be revitalised enough for one trackday... barney Quote
mark.anson Posted May 23, 2010 Posted May 23, 2010 Kev Avon Crossplys A15 rear and A92 fronts will do the job. A15s on the front too will last a bit better if you are double driving, the others may give up for the 2nd driver particularly if its a longer circuit or hot day. Mark Quote
Kevin Jones Posted May 23, 2010 Author Posted May 23, 2010 the others may give up for the 2nd driver Now that idea I like Thanks for comments, BMTR also said A15 all round because of double drive & likely expect 2 sets per season. Quote
