I HAVE A 1700 CROSSFLOW BUT SEEM TO BE HAVING PROBLEMS WITH THE STARTER(LUCAS LRS100).TESTED THE SOLENOID,CHECKED THE RING GEAR AND TESTED THE STARTER THEY APPEAR TO BE ALRIGHT.COULD THIS BE AN ALIGNMENT PROBLEM? THERE IS ALSO AN OPTION OF 9 OR 10 TEETH ON THIS STARTER, THE CURRENT ONE IS 10 TEETH AND I HAVE BEEN TOLD THEY ARE BOTH UNIVERSAL AND IT SHOULD NOT MATTER?
CAN ANYONE HELP?
what sort of problems?
Sluggish turnover? cold or hot (Fairly normal when cold)
wont turnover at all?
wont engage?
What oil grade are you using?
etc etc
more info please! ???
:( ...and stop shouting, we're not deaf.
LRS100 IS DEFINITELY  ALLRIGHT (sorry must keep my voice down) to use with a xflow with type 9 box, make sure your ring gear is in good nick also check that the bendix is spotless and not sticking, it shouldn't be greased or oiled, it doesn't matter whether its 9 or 10 tooth. some late escort mk2's had a pre-engaged starter with a diffrent flywheel though they a pretty rare. If you still can't sort it go in and drink 4 cans of scrumpy jack. :D   ;)  :zzz:
I think you are gatting the hang of this tech talk mate :D
Matt  ???  Are you stalking Doug  ???  :D  :devil:  :)  or does he owe you alcohol  ;)  :D
No just a local I have managed to get him into the 20 century about time I was not the only one from Cornwall  :D but if he owes me a beer I will be in to collect. :0  :0 You know we have only just got elastictrickery down here in deapest darkest Cornwall it has been gas lamps up to now. :D
Blimey...........
:D  :D  :D
Hello Doug. Welcome to the 21st Century (Matt, take note moi boy......). :p  :D
After trying the ten tooth starter went for the nine tooth,tried it surprise,surprise still isnt working.seems to be catching the ring gear for a second then next try just screaming at me.Put car in gear to turn everything over then tried again.Same thing caught the first time for a sec then screams again.Running out of ideas as the ring gear appears to be alright.
No I ment what I said 20th century poor chap still has not got a TV :D
i have had the same proplem ,after swapping starters and solinoid it turned the problem was the battery power it's worth a try (diesel escort worked for me)
