SeiW 2.0l Raceline Zetec
SeiW 2.0 Zetec
With regret my factory built 1997 SEiW with 22K miles on the clock is up for sale.
Bought by myself in 2004 the car was in original condition.  Subsequently over the past 6 years most of the car has been rebuilt by myself (I am a professional engineer and this is my second kit car) in order to perfect its track day handling and Yorkshire B road ride.  The car is now beautifully set up with very neutral handling on the track, enough power to steer on the throttle and enough ride height to be used in the real world as well.
On the track the move to a balance bar brake assembly and drilled and grooved discs at the rear has allowed the full potential of the brakes to be utilised dramatically reducing lap times.  Toyo R888 tyres provide very progressive handling on the limit and wide track suspension has killed previous understeer.
On the local B roads the provision of a heel rest allows for accurate thottle control and heel and toeing on bumpy roads and full weather gear, a long range tank and a heater mean that weekends away are a practical proposition.
The car has always been winter garaged and never seen salt.
So now the boring/exciting bit depending on your persuasion.
Engine
2.0l Zetec with full Raceline rebuild 3K miles ago including;
Raceline fast road cams
Raceline lightened flywheel
Raceline wet sump
Raceline water rail
Raceline inlet manifold
Raceline black powder coated cam cover
Twin Weber 45s with 75mm intake trumpets, Weber throttle linkage and Pipercross foam filter
Raceline rebuilt head with increased compression
Omex fully programmable 3D ignition
Jetted to suit with progression holes modification
175-180bhp approx.
Gearbox, suspension and drivetrain
Type 9 gearbox with quickshift
Wide track front suspension with AR bar
AVO adjustable shocks all round
Independent rear with Sierra LSD
Other
Quick ratio steering rack
Westfield RAC roll bar with boot box modification
Wunoff repackable S.Steel silencer
Twin brake master cyclinders with balance bar set up
Rear drilled and grooved discs
Long range fuel tank
Racetech black suede steering wheel with quick release assembly
Race seats and 4 point harnesses
Fire extinguisher
Tonneau, doors and full weather gear
Toyo Proxes R888 tyres
The car is MOT'd until Oct 2010 which was around 200 miles ago. Comes with spare wheel and rear mount fittings.
Price
Now reduced to £8,000 but strictly no haggling
Contact details
The car is located in Keighley, West Yorkshire.  I'm afraid PM is not a great way to contact me so please either phone me on 07879 457210 or email john@alpinezebra.co.uk if you are interested.
very nice indeed - good luck
  • 3 weeks later...
oooooohhhh i am so getting tempted to buy another....
