Hi there
Just bought a megablade with RAC rollbar fitted,is it possible to fit a boot box or not.
DAZ
It is possible Daz although you will have to cut some holes in it. I am assuming that you are going for a removable one (roolbar), if not then i don't think it will fit, most people just fit a blanking plate of ally of carbonfiber sheet, having no boot box also reduces weight ;)
Andy :t-up:
it can be done with a permanant Westfield supplied RAC roll bar, it takes a bit cutting of the boot box, then the standard boot cover thingy doesn't fit on.  So I made up an MDF boot lid, hinged with a lock on it. Then cut up the origonal boot cover and used it to cover the MDF over.
It works really well, but a boot load of stuff must slow it down no end  :p
Yes the boot box can be made to fit an RAC roll bar, but it's much easier to do if you have one with removable rear struts -mine didn't and was an absolute pig to do.
It is useful to have though and it is only a little heavier than a flat sheet. Plus it looks much better too IMO. :p
Still have my old boot box (I fitted a flat carbon sheet) if you need a template or need to try one for size!
I'm in Herts.
Dave O.
