Pembroke Pat Posted October 31, 2002 Posted October 31, 2002 I went to bolt on the rhs engine mount last night and discovered that one of the mounting points requires a spacer. I then read the manual and it stated that a spacer was required but didn't specify how long or what grade material was required. Has anybody any idea? ( I have been hanging on the phone long enough with westfield for one day) Quote
stu999 Posted October 31, 2002 Posted October 31, 2002 Can you give us a clue as to what engine you are fitting? Quote
Guest Posted November 3, 2002 Posted November 3, 2002 Easiest to get the spacer from the factory - that's where I got mine. I'd let you know the dimensions but I'm building the car elsewhere so can't go and check... - Dan. Quote
Pembroke Pat Posted November 4, 2002 Author Posted November 4, 2002 Thanks guys. I discovered that the alternator support does a fine job as a spacer. Quote
