Hi Guys
Some of you might remember me as I used to post a lot a couple of years ago.
Due to change in hobby and the fact it does not get used anymore I thought it was about time I sold the Megbusa.
pictures of it can be found at.
http://www.bridge-digital.co.uk/
and
http://www.bridge-digital.co.uk/TurboBuild
I am looking for offers close to £16995
I have some pictures I took at the weekend and I will post them tonight. It sailed through an MOT on Friday and has just been taxed for 6months.
Any questions just ask, spec is below.
Bazzer
Introduction
2001 Megabusa on a 51 plate. Built from all new parts from Westfield apart from the engine which had 800 miles on it when I bought it.
Engine
Suzuki Hayabusa engine with a Mitsubishi  TD04-16T turbo which made 284BHP on Dave Walkers rolling road at Emerald. It could make more but it is nice and drivable like this. Engine was fully rebuilt when  turbocharged. Spec includes :-
Crank Lightened, balanced and the balancer shaft removed (by Mistral Racing)
AP racing main bolts.
Carillo H beam steel con rods with AP racing big end bolts, balanced by Mistral.
Up rated output shaft (APE racing).
Billet centre clutch with up rated springs (TTS).
JE forged low compression turbo pistons.
Decompression plate.
Handmade turbo headers (Holeshot)
Alloy Plenum with 4 extra injectors (Holeshot)
Up rated turbo head gasket.
12mm head bolt conversion.
Headers and link pipe ceramic coated by Camcoat.
Adjustable Cam sprockets from (APE Racing)
Forge Motorsport Waste gate.
Tial Blow off Valve.
Front mount Alloy intercooler
Alloy V8 multicore radiator.
Davis Craig electric water pump.
Laminova oil to water oil cooler.
Dry sump system, Westfield oil pan and tank with pace 3 stage pump (2 scavenge 1 pressure stage)
Remote oil filter
Pro Gold hoses and fittings though out oil system.
SBD high capacity fuel rail.
Billet pre and post pump fuel filters.
Bosch motorsport “500bhp” fuel pump.
Pro gold hose and fittings throughout fuel system.
N75 electronic boost controller (controlled by Emerald ECU)
7” * 28.5”  Techcraft exhaust  (quiet  for trackdays)
Engine running on Emerald K3 ECU mapped by Dave walker on the Emerald rolling road. (Have dyno plots)
Professional modular engine loom.
Suspension and wheels
Nitron monotube dampers all round.
Nylon Bushes.
Factory anti rol bars front and rear.
1.9 quick rack
Alloy rack mounts.
13 x 7  Dymag magnesium alloy wheels
Chassis
Megabusa chassis from Westifield with a few mods.
Direct mounings for alloy V8 Radiator and intercooler.
Removable side brace to allow turbo to be removed with engine in place.
Rear diff cage braced and gusseted, done in a similar way to the later high power Duratech factory cars.
Custom Cages bolt in T45 alloy steel light weight roll cage with removable petty strut .
Drive train
6 speed sequential gearbox with high ratio 5th 6th gears (Holehot)
3.36 Ford Scorpio LSD
Brakes
Front Westfield 4 pots with Pagid RS15 pads
Rear Ford Sierra with Pagid RS14 pads
Twin AP master cylinders with balance bar.
Instrumentation
Anodised blue DigiDash II electronic dash with full data logging and infrared lap timer including IR receiver.
SPA Dual gauge for fuel pressure and boost.
Innovate wide band lambda sensor and digital display (also connected to ECU)
Bodywork and fittings
Westfield Orange body work with flared side panels.
Detachable rear arches with carbon effect protectors.
Westfield carbon nose cone.
Fluke motorsport carbon dash.
MOG racing carbon seats.
Driver 6pt Silverstone willians 3” harness.
Passenger 4pt Willians 2” harness.
Blue anodized interior panels.
Body work is  removable in about 15minutes once cage is unbolted. It is fastened with a combination of quick release fastenings and bolts.
New style rear lights
Front indicators on carbon Caterham style pods under headlights.
Westfield steering wheel with SPA quick release boss.
And lots of stuff I have forgotton :-)
Whilst I have not seen the car since the Turbo conversion, Baz is one of those perfectionists :D:D:D and this will no doubt be an excellent car, with as he says lots of little extra's to make it perform just right.
Sorry to see you selling it Baz, but best of luck with the sale.
Cheers Nick
I am just not using it so its shame to have it sitting in the garage. I have not really used it properly for about 2years now.
So its time to move on I think. It does drive really nicely now since I fitted the emerald and had Dave Walker map it.
It is surprisingly easy to drive for such a powerfull light car.
I know you love the supercharger, but the turbo does work really well on the Busa.
Its little things that make a car. Before I turbod the car with the standard setup, I was limited by the oil temp as too how many laps I could do. Now it runs until the fuel runs out and stays cool, with more power :-)
Bazzer
Looks like a really nice car with all the right bits and I bet it reall flies!
Good luck with the sale.
here you go ...
that's one heavenly rocketship - good luck with the sale
Thanks for sorting the pictures and thanks for the nice comments.
Could do with a nice suede Momo steering wheels to finish it off though. I will leave that to the new owner whoever that is :-)
Bazzer
very nice indeed
Think I will take it out at the weekend if its nice. Been ages since I had it MOT'd might make me want to keep it :-)
Bazzer
Very  Nice. Can anyone  tell me where you get those side panels from? Ive converted mine from clams and that would improve it loads by covering the holes. I thought the only way I could get rid of them was to get a new tub.
Greg
The ones on my car were home made so they could be longer to allow for an overlap, those carbon ones linked above are very sexy though :-)
Bazzer
Nice car, i bet it goes like stink!
Would be a real contender in classes 'F' or 'H' in Speed Series!!!!
Hi Bananaman
Didnt you have get a duratech with a sequential just before I gave up trackdays ?
If so you till got it ?
I is an awsome track car so I don't see any reason why it would not be competative in the right hands in speed events.
Its primarily been developed as a track day car that can do lots of laps without overheating etc. But the extra torque from the turbo makes it a bit nicer on the road than a standard Busa. Not that a standard busa is that bad on the road anyway.
Bazzer
