Hastwell Posted May 3, 2010 Posted May 3, 2010 Just bought a starter kit at stoneleigh! Woohoo :-) where should I go for my parts and what should I get off Westfield...could do with a bit of help guys!
DITCH Posted May 3, 2010 Posted May 3, 2010 "BIG Question "? Take a look at the following question's, as it makes a difference on what you will require, and where you will end up buying from !!!! 1) Whats the budget. 2) Want a current Registration or a "Q" Reg. 3) What finish you want. As the answers you give will help the guy's on the Forum direct you to a plentiful of suppliers, either new or used parts. Ditch.
Dave Eastwood (Gadgetman) Posted May 3, 2010 Posted May 3, 2010 Congratulations Andrew, what version have you gone for? (SDV, body/chassis, bike/car engine etc.)
Hastwell Posted May 3, 2010 Author Posted May 3, 2010 Thanks guys... The car is a SEi multi donor with an FW front. It will be used mainly for touring, running a zetec engine. Undecided on the Q plate, depends how much I can save. Trying to keep budget low as possible but still maintaining a good finish. Trying to source the following parts; suspension differential, driveshafts, front uprights, hubs, discs and callipers......virtually everything I will need to get me to a rolling chassis.
Dave Eastwood (Gadgetman) Posted May 3, 2010 Posted May 3, 2010 Some great bargains come up in here regularly; which as a member you'll be able to take full advantage of, though you'll need to be fast on the draw - vultures the lot of us IIRC driveshafts used to come with the kit, though they don't come with lobro joints. (I ordered a new set of joints with my chassis kit, and they came ready fitted). For new components, companies like Cat Motorsport Plays Kool Rally Design, Think Automotive to name but a few have some good priced alternatives to the factory. Ebay can be a great source of parts - but do your research before bidding - it's easy to pay over the odds! And obviously there's scrap yards, though Sierra and Cortina bits are getting scarce nowadays; partly because in the last few years, the "value" of certain kit car friendly bits has been recognised, and there's been a number of companies springing up to source and supply old Cortina uprights, Sierra diffs etc
DITCH Posted May 3, 2010 Posted May 3, 2010 Hi, Have a gander's on E bay, there are plenty of Ford Zetec Engine's for sale. Kitpartsdirectltd have some smashing deals on "Brand New 2ltr Zetec's" for start off bid at £590 (CHEAP) !!!! Or if the budget won't go that far, there are a load of used silver top's for sale on there. There are other item's on there as well ( MT75 gearbx's) etc, that may well come for the right money !!! If you need any more advise don't hesitate to PM me as well !!! Ditch.
FW500 Posted May 4, 2010 Posted May 4, 2010 Personally I tried to avoid using the factory as much as possible. Some things I found reasonably priced from the factory such as their wiring loom but other things I found to be massively overpriced in my opinion. I didn't have any problem getting an '08 plate - just make sure you keep all invoices and keep a proper build file with plenty of pictures.
Hastwell Posted May 5, 2010 Author Posted May 5, 2010 Yeah I will get the wiring loom off Westfield. Is there anything else I should get off them as I get 10% show discount? Can I use rally design uprights, are they any good? What records do I need to keep for IVA? Cheers Andy
Mark (smokey mow) Posted May 5, 2010 Posted May 5, 2010 What records do I need to keep for IVA? Keep the receipts for anything major you buy (ie pretty much everything except for nuts and bolts), and if buy from ebay etc take a printout of the listing if you don't get a receipt. Also be sure to take lots of photos during the build process to show that it was ameteur built by you and not by a business. I found a few wide angled photos showing the washing line and flower beds in the background proved it was built in my garden
RedditchJay Posted May 5, 2010 Posted May 5, 2010 Dont listen to DITCH.... have you seen the state of that engine bay.... rumour has it it got dirty once..... back in 2002... me... jealous,,,nnnnaaaahhhhhhh..............OK..YES I AM
XTR2Turbo Posted May 6, 2010 Posted May 6, 2010 I have lots of bits taken off an 08 car with just 500 miles. I have all the original receipts. 1.6 all alloy Ford sigma engine and everything that you don't get with a crated engine off ebay required to install in a Westfield such as starter, alternator, flywheel, clutch, clutch cable and fork, bellhousing for type 9, coil, leads, water pipes to connect to Westfield rad, complete Westfield exhaust system etc. All you need is ECU and engine wiring loom I have a video of the engine running perfectly in the car before I took it out. In this spec the engine is 120bhp. A cam change would give about 130bhp and throttle bodies as on the caterham R300 gives about 155bhp I also have front brake calipers and disks, nose indicators and propshaft. Call me on 07907 977 304. Looking for about £850 for the lot.
adamnreeves Posted May 6, 2010 Posted May 6, 2010 Congratulations on buying into one of the best marques. See you've also become a member, good choice. You've made a posting in the parts wanted section with topic of "New Kit", thought that's what you wanted until I read the post
FW500 Posted May 6, 2010 Posted May 6, 2010 If it helps I recorded most of the costs (excluding the cost of the engine) and where I sourced the parts. It's not complete and is obviously a few years out of date now but it may help. 21/11/2006 Westfield Sportscars Ltd SEIW - Rolling Chasis £4,953.55 21/11/2006 Westfield Sportscars Ltd 2000s Chasis £467.05 21/11/2006 Westfield Sportscars Ltd FW Style bodywork upgrade £467.05 21/11/2006 Westfield Sportscars Ltd Nylon Bush upgrade £93.41 21/11/2006 Westfield Sportscars Ltd AP Racing 4 Pot Caliper / Disc kit upgrade £518.95 28/07/2006 Sorensen Road Sport FSE Bullett Filter £50.00 29/01/2007 Sorensen Road Sport 15" Team Dynamics Wheels & Toyo R888 Tyres £685.00 03/02/2007 Sorensen Road Sport 3 Ltrs Silkolene BOA90LS Differential Oil £23.00 05/02/2007 Kevin Cooper Motor Factors Ltd Driveshaft £93.24 17/02/2007 Sorensen Road Sport Helix Clutch Cover - Vauxhall £224.92 17/02/2007 Sorensen Road Sport Helix Centre Plate - 228mm £170.34 01/03/2007 Westfield Sportscars Ltd Wiring Loom - OHC £236.15 06/03/2007 Westfield Sportscars Ltd Propshaft - T5-Sierra Diff £183.72 06/03/2007 Westfield Sportscars Ltd 2 x CV Joint Shroud £8.39 06/03/2007 Westfield Sportscars Ltd Fuel Pipe 1830mm £14.81 15/03/2007 Westfield Sportscars Ltd T9 Gearbox Mounting Rubber £11.65 15/03/2007 Westfield Sportscars Ltd Handbrake Warning Switch £11.71 30/03/2007 Sorensen Road Sport Sparco Motorsport Horn £27.00 30/03/2007 Bearingkits.co.uk Cosworth T5 Spigot bearing £7.99 31/03/2007 A Frame Engineering Alloy Bellhousing Astra 16v - Cosworth T5 £199.75 03/04/2007 Westfield Sportscars Ltd Grommet - Wiring 1 3/4" Dia £4.10 04/04/2007 Vospers Motor House Clutch release arm £24.11 01/05/2007 Westfield Sportscars Ltd 2 x Engine Mounting Rubber £15.75 01/05/2007 Westfield Sportscars Ltd Clutch Cable - Ford 2000 £8.09 01/05/2007 Westfield Sportscars Ltd Carriage £3.53 04/05/2007 Sorensen Road Sport 6 x FSE -6 Pro Finishers (Blue) £21.08 04/05/2007 Sorensen Road Sport 6m x FSE s/s inj hose (8mm) £47.87 09/05/2007 Sorensen Road Sport Helix Release Bearing £24.17 09/05/2007 Sorensen Road Sport AH Fabrications Foam Filled Fuel Tank £375.49 15/05/2007 Sorensen Road Sport 6 x FSE -6 Pro Finishers (Blue) £21.08 26/05/2007 Sorensen Road Sport red Top 30-Flash 1000 Gel Battery £110.00 12/06/2007 Vehicle Wiring Products Ltd Thinwall wire £0.66 12/06/2007 Vehicle Wiring Products Ltd Spiral Binding 6mm & 12mm (25m each) £20.33 12/06/2007 Vehicle Wiring Products Ltd Conv' tube slit 7mm & 11.5mm (5m each) £7.05 12/06/2007 Vehicle Wiring Products Ltd Black PVC Beading £9.34 12/06/2007 Vehicle Wiring Products Ltd 100 x S/A zip-tie bases £10.53 12/06/2007 Vehicle Wiring Products Ltd 12mm bore Braided S/S Fuel Hose (1m) £22.17 12/06/2007 Vehicle Wiring Products Ltd Carriage £4.40 23/06/2007 Sorensen Road Sport Tilton Adjustable Hydraulic Clutch Billet Base £254.66 23/06/2007 Sorensen Road Sport Tilton Release Bearing - T5 Late £93.24 25/06/2007 SBD Motorsport Ltd 70deg Thermostat £31.73 25/06/2007 SBD Motorsport Ltd Low Line (100mm) Sump Kit 2.0L XE 16v £225.41 25/06/2007 SBD Motorsport Ltd 2 x Sump Gasket 2.0L 16v XE £16.47 25/06/2007 SBD Motorsport Ltd Carriage £23.28 09/07/2007 Evans Halshaw 6 x studs £3.88 09/07/2007 Evans Halshaw Belt £34.60 02/08/2007 Wipfler Keller Stahl GbR Motosign Schwarz (Black) £100.00 18/08/2007 Sorensen Road Sport 3 x SFS 90 deg 32mm Elbow - Yellow £26.41 18/08/2007 Sorensen Road Sport 2 x SFS 38 > 32mm Reducer - Yellow £20.77 18/08/2007 Sorensen Road Sport 3 x SFS 90 deg 35mm Elbow - Yellow £30.37 18/08/2007 Sorensen Road Sport 2 x SFS 35mm Straight hose (1m) - Yellow £48.99 18/08/2007 Sorensen Road Sport 1 x SFS 63mm Straight hose (1m) - Yellow £41.21 18/08/2007 Sorensen Road Sport 2 x SFS 90 deg 76mm Elbow - Yellow £53.91 18/08/2007 Sorensen Road Sport 1 x SFS 76 > 63mm Reducer - Yellow £18.49 18/08/2007 Sorensen Road Sport 3 x SFS 32mm hose joiner £20.17 18/08/2007 Sorensen Road Sport 6 x SFS 35mm hose joiner £38.43 18/08/2007 Sorensen Road Sport 2 x SFS 76mm hose joiner £31.47 18/08/2007 Sorensen Road Sport 1 x SFS 63mm hose joiner £14.01 18/08/2007 Sorensen Road Sport 5 x Murray clip - 64mm > 86mm £29.20 18/08/2007 Sorensen Road Sport 3 x Murray clip - 50mm > 73mm £16.25 18/08/2007 Sorensen Road Sport 10 x Murray clip - 28mm > 38mm £59.69 18/08/2007 Sorensen Road Sport 20 x Murray clip - 41mm > 60mm £119.38 31/08/2007 Vehicle Wiring Products Ltd Loom terminals / housings / boots £91.06 31/08/2007 Vehicle Wiring Products Ltd Conv' tube slit 16.5mm. 23.5mm & 19.5mm (10m each) £39.01 11/09/2007 Sorensen Road Sport 1 x SFS 35mm Wire hose - Yellow £41.99 11/09/2007 Sorensen Road Sport 1 x SFS Coolant Hose 13mm - Yellow £16.50 11/09/2007 Sorensen Road Sport 3 x SFS Coolant Hose 8mm - Yellow £37.02 11/09/2007 Sorensen Road Sport 1 x SFS 35mm hose joiner £8.55 11/09/2007 LSUK Single Earth Baird £2.70 11/09/2007 LSUK V-Belt £3.78 11/09/2007 LSUK Micro V Belt £7.61 28/11/2007 SBD Motorsport Ltd 2.0L XE Taper Inlet Manifold, water elbow, fuel rail £285.76 28/11/2007 SBD Motorsport Ltd 2.0L Carbon Spark Cover with SBD Logo £94.88 28/11/2007 SBD Motorsport Ltd Carriage £15.44 10/12/2007 Jenvey Dynamics Ltd SF Assy spec; 4 bodies £135.13 10/12/2007 Jenvey Dynamics Ltd 4 x Tapered Throttle Bodies £498.20 10/12/2007 Jenvey Dynamics Ltd Linkage Kit £103.40 10/12/2007 Jenvey Dynamics Ltd Linkage brackets & rod £21.15 10/12/2007 Jenvey Dynamics Ltd Throttle Pot - Colvern CP17 £55.81 10/12/2007 Jenvey Dynamics Ltd 4 x 19mm Air Horns £70.50 10/12/2007 Jenvey Dynamics Ltd Carriage £11.75 10/12/2007 Laser Cutting 5mm Pulsar Plenum Backplate £50.00 10/12/2007 Laser Cutting 12mm Pulsar Plenum Spacer £70.00 11/12/2007 Laser Cutting Plenum programming £41.13 11/12/2007 Eurocarb Ltd Weber synchrometer £38.90 12/12/2007 Sorensen Road Sport Mocal Oil Pressure Switch 35Psi £16.98 12/12/2007 Sorensen Road Sport 2 x Mocal Plug Male > Female 1/BNPTF £9.33 12/12/2007 Sorensen Road Sport Carriage £4.69 17/12/2007 SBD Motorsport Ltd Ultra small 55amp 3.2kg Alternator & Mount kit £235.15 03/01/2008 Hiflex Fluidpower Oil cooler hose assembly £36.78 12/01/2007 Sorensen Road Sport FSE MSV Racing Valve £85.00 04/02/2008 Stafford Vehicle Components Ltd Pair of Landrover Lights - Clear lens, Amber bulb £12.00 04/02/2008 Stafford Vehicle Components Ltd 2 x LED Indicator Outers £40.00 04/02/2008 Stafford Vehicle Components Ltd 2 x LED Stop/Tail Outers £40.00 04/02/2008 Stafford Vehicle Components Ltd 2 x LED Stop/Tail Inners £35.00 04/02/2008 Stafford Vehicle Components Ltd 2 x LED Reverse £90.00 04/02/2008 Stafford Vehicle Components Ltd Pair of Hella Inner Rear Fogs £20.00 04/02/2008 Stafford Vehicle Components Ltd Pair s/a reflectors £6.00 04/02/2008 Stafford Vehicle Components Ltd Carriage £6.00 07/02/2008 Sorensen Road Sport 3 x SFS Silicone Tape - Yellow £20.89 07/02/2008 Sorensen Road Sport 2 x SFS 45deg 35mm elbow - Yellow £21.67 07/02/2008 Sorensen Road Sport 1 x SFS 90deg 35mm elbow - Yellow £9.29 07/02/2008 Sorensen Road Sport 1 x SFS 25mm Straight hose (1m) - Yellow £18.20 15/02/2008 Sorensen Road Sport Stack ST700-SR Dash System £450.44 15/02/2008 Sorensen Road Sport MSD Blaster 2 Coil £39.55 20/02/2008 Vehicle Wiring Products Ltd 50 x 6.3mm Male, Female & Piggyback Terminals £8.98 20/02/2008 Vehicle Wiring Products Ltd Grommets £2.08 20/02/2008 Vehicle Wiring Products Ltd 10m x 20/030 Cable £4.23 26/02/2008 Parrs 2m x Wide Rib Rubber Matting £34.05 05/03/2008 Stafford Vehicle Components Ltd C/E No. Plate Light £17.00 06/03/2008 Westfield Sportscars Ltd Body Fitting Kit - FW Style £141.00 08/03/2008 Sorensen Road Sport Mocal s/s braided 5/8" ID x 1m £18.50 22/03/2008 Sorensen Road Sport Roll Cage Padding £29.85 Carbon Mods Aeroscreen £140.00 Ebay T5 Gearbox £200.00 Ebay Diff £150.00 Passionford T5 Gear lever £30.00 Ebay Mk1 Renault Clio Stalk £10.00 ZenaRacing Yellow vacuum hose £13.00 EDS Motorsport Teflon Rose Joints £10.50 Ultimate Lighting Pair BMW E36 side repeaters £17.94 Bob Heywood Pulsar Plenum £30.00 Kevin knight Indicator pods £35.00 D Wynton V8 Radiator £300.00 Jeff C RAC Roll Bar £150.00 WSCC SVA Steering Wheel £30.00 Westfield Sportscars Ltd Expansion Tank £35.00 Sorensen Road Sport 4 Point Harnesses £240.00 Sorensen Road Sport Battery Cover & MSD Coil Bracket £30.00 JK Composites Seats £350.00 Racing Cars Direct Fuel Pump Bracket £20.00 Sorensen Road Sport Stack oil pressure & water temp loom Sorensen Road Sport Fuel filler cap £100.00 MADevelopments Bosch 044 Fuel Pump £100.00 Ebay Lobro Joints £50.00 Sorensen Road Sport Mocal oil catch tank £70.00 Mickmade Carbon Dash £95.00 Ebay SPA Carbon mirrors £70.00 Mig Billet Lightened Flywheel £190.00 Oil cooler £35.00 Racetech centre mirror £25.00 MADevelopments Autronic SMC £500.00 MADevelopments Mapping £350.00 VOSA SVA £158.00 AP Motors Exhaust £300.00
