Instruments
I am looking at getting some more instruments, any recommendations?  I would prefer white dials?
Anyone know of any second hand ones going?
I got a set from ETB here who have been incredibly helpful as I had a problem with my Weber Alpha ems box sending the right tacho signal - very recommended....I've also seen mentions for Greeengauges  here
not sure you'll find white faced ones secondhand but then again you could ask someone like ETB to change the faces for you (though how much this would cost I've no idea ;) )
Mocal do some decent white faced guages - but they may be only mechanical.  SPA have, I think, also started doing some white faced guages too.
Also check out Raceparts for Racetech guages.
Finally, check out Stack.  I know it's expensive but the all in one dash displays are bl**** good !!  And there's a white faced one (which I use) specifically designed for road use.
If you're interested in the Stack or SPA stuff then go to www.racecar.co.uk ( Racecar ) and look on the parts board under the for sale section.  There's a chap called Keith Connolley (KC) who does Stack and SPA at reduced prices and who sometimes has secondhand bits.
