Nice easy question: I know I need a spigot bearing for my Zetec but having not yet got one, I was wondering what it does.
Thanks.
Its a bearing that sits in the tail of the crankshaft, which the gearbox input shaft slides into, allowing it to be supported from both ends.
HTH Stu
You will need a spigot bearing this fits in the crank shaft Ford part No.1596468.cost £3.20
Paul.
Cheers,
Am I right in assuming that Zetecs don't have a spigot bearing as standard then because the Mondeo is front wheel drive & so does not have a long input shaft that needs supporting?
You will need to fit one.
Imade up a tool for tapping this bearing in with do you want to borrow it as using a pin punch will b******* it up.
Paul.
You have assumed correctly. :)
