Clutch cable fitting
just assembling my floor mounted pedals - SEiW starter kit
Sorry for being dumb but I can't seem to work out which way round/how the clutch cable is fitted, the manual only seems to refer to a clutch master cylinder..
One end has an eye type connector, i think this end connects to the pedal and a plastic assembly (how does this work?).
The other end has a solid pear shape connection (clutch end?)
Any advice, Thanks.
hey dave, once you have mounted the pedals and drilled the holes throught the bulkhead for the cable to run through take out the cable from the outer sleeve and feed the cable through the bulkhead so that the eye connector is between the bottom of the pedal, fix this in place with a bolt and washers or a clevis pin and split pin (not to tight though)
On the engine side of the bulkhead refit the outer sleeve to the cable and silicone seal the outer sleeve to the bulkhead. job done.
when it comes to connecting to the engine simple task and should be straight forward.
sorry for the length but it sould help
Cheers Pete
