windscreen fittings
hi all,
Just purchased a windscreen and pillars kit from westfield can anyone tell me if the screen should have a rubber strip along the bottom where it sits on the scuttle as this did not come with the order.They didn't send the instructions for fitting i ask for either ,has anybody got any they could e mail me my car is a narrow body/prelit.
Many thanks
No, they don't supply a rubber strip.  You need to get some sticky-backed closed cell foam from Woolies or Europa and stick this on the screen bottom edge.
Sorry, can't help with fitting instructions but be careful, AFAIK they are very model specific.  You would be better off getting instructions from Westfield then, if they are wrong, you at least have a comeback.
HTH
cheers stu are westfield spares always this bad they forget to send bolts etc to.
Don't be too hasty.
Your said your  car is a Pre-lit  ;)  :D  elsewhere.
If you purchased the current Westfield windscreen - it will not fit  ;)  ???  The pre-lit screen is different. You have a rubber strip with pre-lit screens not current ones.
Did you tell the guys at Westfield you wanted a windscreen for a pre-lit model  ???  ;)  As most pre-lit stuff is special order and usually not readily available "off the shelf"  :(  ???  ;)  Have you got the correct screen ?
As for not including the bolts and fixing bits - no comment
hi Mark,
i told the guy it was a prelit he said a narrow body screen would fit is this wrong?
I've left you a reply on your other thread on this subject  ;)
