zetec 1.8 engine + raceline bits
1.8 silver top came from LNT it's done 12 races in a g20 so less than 2,000 miles from new ie never been in a mondeo etc, it's got 130 spec cams,arp rod bolts,short sump,correct water pump, sachs clutch,and bearing for type 9 in flywheel
also with it
raceline water rail (brand new)
raceline stainless steel exhaust manifold for a westfield (brand new)
rs 2000 alloy bellhousing with cut sides to fit in transmission tunnel so no need for crappy remote linkage on gear stick,for a type 9 box (brand new)
weber alpha management set up for this engine
inlet manifold for weber carbs or throttle bodies (no carbs with it)
engine mountings for a westfield but they are hard mounts with metalastic suspension bushes so more suitable to a track car
small nissan micra alternator and associated brackets to fit the zetec
all engine wiring
can be seen running
in short all you would need is a silencer (i could get you a new one from wunoff about 200 quid) and a type 9 gearbox and a set of carbs
the only reason for sale is it's out of the class structure i want to go in in the harewood championship
SOLD
Please god NO - tell us that you are not engine swapping again  :bangshead:  :p
Stew,
If you decide that you'd split some of the bits I'd be interested in the water rail, alternator & bracket pls.....
Vulture mode off....  :D
Cheers,
Mark.
sorry mark its all sold
ah balls  :bangshead:  :bangshead:  :bangshead:  Was very very tempted. Too much thought time taken  :down:
Go one, put us all out of our misery. What you putting in.
CBR1000rr..............you know it makes sense. :p  :p  :D
speak to Stu anyway, he has a source for 1.8 zetecs  ;)
Might not be a bad idea in the long run ???
not any more rich there all gone
