pistonbroke Posted March 1, 2010 Posted March 1, 2010 Thought I would give IE8 + SP3 a try , should have known better Downloaded it and the instal failed , then the programme automatically deleted but when I re booted Windows tries to load but wont run . Apparently the file hal.dll is missing or corrupted anyone know how to fix this without using too big a spanner Ps its a HP desktop with a partition for recovery (no disk) I need to keep the stuff thats on the HDD . Quote
Man On The Clapham Omnibus Posted March 1, 2010 Posted March 1, 2010 Try starting in safe mode and using system restore to go back to before the catastrophe? That's the extent of my knowledge I'm afraid. BTW, how you doin' this without a computer? Quote
Blatman Posted March 1, 2010 Posted March 1, 2010 Put your Windows CD in and copy the hal.dll from the cd in to the appropriate file on the hard drive. Quote
Dave Eastwood (Gadgetman) Posted March 1, 2010 Posted March 1, 2010 Ps its a HP desktop with a partition for recovery (no disk) I need to keep the stuff thats on the HDD . Keep up Blatters Quote
Dave Eastwood (Gadgetman) Posted March 1, 2010 Posted March 1, 2010 First question, can you boot up the PC in safe mode, (press F8 while it's starting up)? Quote
pistonbroke Posted March 1, 2010 Author Posted March 1, 2010 First question, can you boot up the PC in safe mode, (press F8 while it's starting up)? wont boot at all in any mode available . according to HP Help and support here i've tried re building the file as they suggest but the PC cant find the boot.ini file searched the HDD and boot.ini appears to be missing the hal.dll is a driver is a critical file required for windows boot and unique to my model HP Pavillion . I have tried to create a recovery CD from DOS but it wont let me do this because a recovery disk set has been produced previously and your only allowed one go. presume ive done this in the past but if so I think the bin man collected them in a loft clear out about 4 years ago. Thinking my solution is another hdd with windows xp loaded on and connect my existing hdd as "slave" so i can recover my files , family pics, history and etc. Quote
Blatman Posted March 1, 2010 Posted March 1, 2010 If you have another PC to use to drive a caddy, whip the HDD out of the dead machine, hook it up to the caddy and install the hal.dll and whatever else needs doing and then put it back in to the computer. According to my HP laptop, hal.dll resides in two places... C\WINDOWS\system32 and C\WINDOWS\SoftwareDistribution\download\dd9ab5193501484cf5e6884fa1d22f9e It's also gotta be worth looking at Microsoft Knowledgebase for SP3 and HP issues. You can't have been the first to have this happen. And when you get it back, remove SP3 and replace with SP2. Neither of my machines has SP3, and after participating in a project to roll out SP3 to a reasonably large network, I'm in no hurry to "upgrade". SP3 was (and maybe still is) pretty good at trashng computers, especially laptops... Quote
John Williams (Panda) - Joint Manchester AO Posted March 1, 2010 Posted March 1, 2010 my 2 penth... although it says hal.dll its not can you get to a command prompt? if so run run chkdsk c: /p if not pm me and i'll get you a disk..... trust me i'm an IT engineer!!! cheers john Quote
pistonbroke Posted March 1, 2010 Author Posted March 1, 2010 Thanks for that John , ive run chkdsk but not with those perameters so will try again and let you know how it goes Quote
pistonbroke Posted March 1, 2010 Author Posted March 1, 2010 If you have another PC to use to drive a caddy, whip the HDD out of the dead machine, hook it up to the caddy and install the hal.dll and whatever else needs doing and then put it back in to the computer.According to my HP laptop, hal.dll resides in two places... C\WINDOWS\system32 and C\WINDOWS\SoftwareDistribution\download\dd9ab5193501484cf5e6884fa1d22f9e It's also gotta be worth looking at Microsoft Knowledgebase for SP3 and HP issues. You can't have been the first to have this happen. And when you get it back, remove SP3 and replace with SP2. Neither of my machines has SP3, and after participating in a project to roll out SP3 to a reasonably large network, I'm in no hurry to "upgrade". SP3 was (and maybe still is) pretty good at trashng computers, especially laptops... I have access to another PC but need to wait untill HID is out shopping It isnt a HP, so not sure if the files i need are on there. I'm thinking of buying a new to me HDD and a copy of win xp so in future I can use /repair any problems independant of HP , hopefully I can then copy my files over to the new HDD Edit to update Just found this , highlights the problem with some suggested solutions ....... microsoft looks like I need a recovery disk Calling Mr Williams (put that guitar down and check your PM) Quote
