'foam pour' seats
Hi Guys,
have recently done a foam seat pour, and ideally would like to look at what options are available to cover it with a fabric of some sort ? rather than just the usual scruffy looking tank tape ??
anyone done this and can recommend a fabric and glue that suits the application ??
Cover it in GRP or use it as a buck to make a mould
There is a cover that is made for these, can't remember what it is right now but will try and find out :D
great - let me know  :D
covering in GRP is not an attractive option... and making a buck would be a waste of time - as I'd need the inverse of what i have right now - so two bucks to be made...
just want to know if there is a light material and suitable glue that i could source..
or maybe dash flocking stuff could be used ??
Dash flocking is usually alcantara. S'nice... but sliding in to a seat covered with alcantara whilst wearing a race suit means it rides up in places :0
I'd cover it is some garden variety vinyl...
garden variety vinyl ??
i ain't got the greenest fingers blatman... and pointers ?
Garden variety = plain, ordinary, normal...
Woollies Trim sell vinyl by the metre...
ta muchly - different world out there !!  some options there... can;t help but think 'Vinyl' would be too thick and hard to work with compared with light 'nomex' type material i had pictured in my head... but at least its a viable option...
Thanks again...
might be easier and get better results taking it to a local trimmer.. Theyre not that expensive.. Theyll do a much better job.. Bigger smiles
Ps you gotta take video footage of you pouring the foam if you havnt done it yet.. Supposed to be a right ole messy job!
lol  i told my mate that camera's - including mobile phones were banned when we were doing the pour !!
thank god too - i was a bit stressed when we mixed it  :p
all turned out ok though... have finished it by adding a few blobs of fiberflass here and there to strengthen and help where it was fairly porous etc....
am planning to talk to a local upholsterer tomorrow that used to do motorbike seats for me - so my be able to help......
will post of pick of any finished result
Is it time for the canoe story again? :oops:
go on then... now you've started....
ish !!
Oh Yes  :t-up:  :t-up:  :t-up:  :D
Perfect bed time story, just keep all liquids away from the keyboard.
YOU'VE BEEN WARNED
Ive considered doing a foam seat in the sprint car but as I sit fairly close to the wheel it would mean a lot of foam between my back and the rear bulkhead. Is there a way of reducing this. I any case how do you get support for the shoulder area. At least a GRP seat gives a little lateral support in this area, or isnt it a problem!
Are you sitting comfortably? Then I'll begin...
A friend of mine once built a canoe. He spent a long time on it and it was a work of art. Almost the final phase was to fill both ends with polyurethane expanding
foam. He duly ordered the bits from Mr Glasplies (an excellent purveyor of all things fibreglass) and it arrived in two packs covered with appropriately dire warnings about expansion ratios and some very good notes on how to use it. Unfortunately he had a degree, worse still two of them. One was in Chemistry, so the nstructions got thrown away and the other in something mathematical because in a few minutes he was merrily calculating the volume of his craft to many decimal places and the guidelines got binned as well.
He propped the canoe up on one end, got a huge tin, carefully measured the calculated amounts of glop, mixed them and quickly poured the mixture in the
end of the canoe (The two pack expands very rapidly).
I arrived as he was completing this and I looked in to see the end chamber over half full of something Cawdors Witches would have been proud of. Two
thing occurred to me, one was the label which said in big letters "Caution - expansion ratio 50:1" (or something similar) and the other that the now
empty tins said "approximately enough for 20 small craft."
Any comment was drowned out by a sea of yellow brown foam suddenly pouring out of the middle of the canoe and the end of the canoe bursting open. My
friend screamed and leapt at his pride and joy which was knocked to the ground as he started trying to bale handfuls of this stuff out with his hands.
Knocking the craft over allowed the still liquid and not yet fully expanded foam to flow to the other end of the canoe where it expanded and shattered that end as well. A few seconds later and we had a canoe with two exploded ends, a mountain of solid foam about 4ft high growing out of the middle, and a chemist firmly
embedded up to his armpits in it. At this stage he discovered the reaction was exothermic and his hands and arms were getting very hot indeed. Running about in small circles in a confined space while glued to the remains of a fairly large canoe proved ineffective so he resorted to screaming a bit instead. Fortunately a Kukri was to hand so I attacked the foam around his hands with some enthusiasm. The process was hindered by the noise he was making and the fact he was trying to escape while still attached to the canoe.
Eventually I managed to hack out a lump of foam still including most of his arms and hands. Unfortunately my tears of laughter were not helping as they accelerated the foam setting.
Seeking medical help was obviously out of the question, the embarrassment of having to explain his occupation (Chief Research Chemist at a major petrochemical organisation) would simply never have been lived down. Several hours and much acrimony later we had removed sufficient foam (and much hair) to allow him to move again. However he still looked something like a failed audition for Quasimodo with red burns on his arms and expanded blobs of foam sticking everywhere. My
comment that the scalding simply made the hairs the foam was sticking to come out easier was not met with the enthusiasm I felt it deserved.
I forgot to add that in retrospect rather unwisely he had set out to do this deed in the hallway of his house (the only place he later explained with sufficient headroom for the canoe - achieved by poking it up the stairwell.
Having extricated him we now were faced with the problem of a canoe construction kit embedded in a still gurgling block of foam which was now irrevocably bonded to the hall and stairs carpet as well as several banister rails and quite a lot of wallpaper.
At this point his wife and her mother came back from shopping......
Oh yes - and he had been wearing the pullover Mum in law had knitted him for his birthday the week before.
