neo Posted January 18, 2010 Posted January 18, 2010 Ok i am now thinking of spliting up the SBD spec REDTOP engine for parts (i dont want to do this to be honest but might have to, to help it sell) HEAD & SPEC (BUILD COST £2244 PLUS LABOUR) COSCAST 16V HEAD PORTED, POLISHED HIGH FLOW HEAD INLET VALVES SBD 1mm OVERSIZE 34mm EN24 STAINLESS COATED VALVES (VLV-442) EXHAUST VALVES SBD 1mm OVERSIZE 30mm EN24 STAINLESS COATED VALVES (VLV-443) VALVE SPRING SEATS SBD RACE VALVE DOUBLE SPRING SEATS (VLP-9K) VALVE SPRINGS SBD RACE DOUBLE VALVE SPRINGS (VLS-05K) VALVE SPRING CAPS SBD TITANIUM RACE SPEC VALVE CAPS (VLC-7K) CAM FOLLOWER SOLID SBD SOLID CAM FOLLOWER SET (CMFL-2S) VALVE UDG SHIMS SBD UNDERGROUND SOLID SHIMS (SHM-7-UGD) VALVE COLLETS SBD VAUXHALL STD VALVE COLLETS INLET CAMSHAFT SBD RACE INLET CAM (CM16V2-M304IN) EXHAUST CAMSHAFT SBD RACE EXHAUST CAM (CM16V2-M295EX) BLOCK & SPEC (BUILD COST £1420 PLUS LABOUR) BOTTOM END VAUXHALL 2.0 16V XE BLOCK CRANKSHAFT VAUXHALL 2.0 16V XE STD BALANCED CRANK PISTONS SBD OMEGA 87.00mm POCKETED RACE PISTONS (OMEGA SBD 3520) MAIN SHELLS MAIN BEARING SHELLS 0.25mm BIG END SHELLS BIG END BEARING SHELLS 0.25mm HEADBOLT SET ARP HEAD STUD & NUT CONVERSION (ARP) BIG END BOLTS ARP 2000 BOLT SET (ARP2000) CONRODS H BEAM STEEL CONROD SET DRY SUMP SYSTEM (NEW COST £1100) PACE DRY SUMP KIT COMPLETE ALL NEW (EXCEPT FOR PUMP) PUMP HAS DONE APPROX 8 EVENTS OR 3 HOURS USE OIL TANK AND PIPES (USED) FUELING & MANAGEMENT (NEW COST £2060) (18 MONTHS USE APPROX 5 HOURS RACE USE) JENVEY TAPER THROTTLE BODIES JENVEY XE MANIFOLD JENVEY THROTTLE LINKAGE JENVEY FUEL RAIL COSWORTH YELLOW INJECTORS JENVEY 45MM TRUMPETS PIPERCROSS SUASAGE FILTER & BACK PLATE EMERALD M3D ECU MICELANIOUS PARTS ALL PART BRAND NEW NOT USED UNLESS STATED SBD EXTERNAL TRIGGER FRONT PULLEY (NEW) SBD CARBON PLUG COVER (NEW) SBD PEZO INJECTORS (INJ690P)(NEW) SBD 70 DEG COOL STAT (NEW) ALCON 3KG BILLET FLYWHEEL (4 EVENTS OLD) DRY SUMP ROCKER COVER AND BELT COVER MAGNEGCORE RACE SPEC LEADS (4 EVENTS OLD) EARLY XE TIMING BELT KIT (NEW) VERNIER PULLEY SET (USED) DISTRIBUTOR BLANK PLATE(USED) I AM LOOKING FOR INTERESTED PARTIES/OFFERS FOR THE ABOVE PARTS BEFORE I SPLIT IT, ID MUCH RATHER SELL AS WHOLE TO BE HONEST AND WONT STRIP TILL IVE SECURED SALES ON THE HEAD AND BLOCK.. barnsey1971@aol.com thanks Rob
Barry Ashcroft Posted January 18, 2010 Posted January 18, 2010 Rob have I missed the advert with it for sale as a whole?
neo Posted January 19, 2010 Author Posted January 19, 2010 Barry its still whole now and for sale on piston head mate, at £5995 or serious offers thats for the whole kit and caboodle... Price is flexable within reason..
Matt Seabrook Posted January 19, 2010 Posted January 19, 2010 That's a lot of kit for that money. It always sounds a lot of money for an engine but when you think of the build cost of this engine its not. Barry are you thinking of joining the four cylinder brigade
neo Posted January 19, 2010 Author Posted January 19, 2010 Basically the price ive advertised it for doesnt even cover the cost of the parts ive used to build it, never mind the machine shop labour and build time, and daft stuff like powder coating covers and stuff, i think if things are priced right they sell, im not greedy but in no panic to sell it ethier....
neo Posted January 19, 2010 Author Posted January 19, 2010 Now sold subject to collection and payment
