Oil Overfill - Plum of Smoke??
Hi, all.  Back again.
Put about half litre of oil in my crossflow which has minor oil leak, and now reads max on drip stick..
I was out of spin and got a nice plum of blue smoke from exhurst when pulling between 6.5-7k revs.
Never happen before putting oil in... have I over filled or should I be worried.
Engine seems to run fine otherwise....
Just this nice plum of smoke if I push it to much.
oh, 1300 crossflow,
high pressure piston Compression  appox 10.5.1
Ford GT Cam Shaft(Sport XR2)
High Pressure Oil Pump
Minisport 1600GT Stage 2 Head
Thanks for the help
Probably has been over filled slightly. I wouldn't worry about it too much, X/Flow's are very good a finding the oil level that they are happy with.
Yep normally through every seal on the engine  :laugh:
Oi... That's harsh!
But fair...
:D
That said mine was oil tight when it departed. The gearbox on the other hand....
I've got a 1300 xflow I'm putting into a fury.  Hasn't got any oil in it and there's still a puddle underneath!
:laugh:
Thanks guy's I will keep eye on it.  Hopefully sort it's self out.
Mart
seen plenty of 10K + BDA's. they all leak
they've kept the oil industry in business for the last 40 yrs  :t-up:
There isn't a strange chill in the garage is there ??? Do the lights go on and off by themselves........................
