Dodgy wiring loom?
:( Help required , 90,se x/flow loom butchered.  :arse:  :A***
Had five wires cut ,previuos owner sold the engine and cut
all wires :durr:  :arse:   1,white+brown=oil sensor :D
2,green+blue=water temp sensor :D .Now heres where things
get confusing,3,brown+yellow????  4,light grey?????????
5,black+white ??.    two must be coil - + but which ones,?
If so, whats the other:durr:  :durr:  :durr:
They are on drivers side ,just below the hole in side of the
bonnet,where twin 40s will go eventually  :0
 Anyone got any ideas what to do.?
     Desperately seeking sus##  guidance pleeeeeease!
cheers rob :devil:
Rob, Some early SE's used the donor MK2 Escort loom too. Have you got or know somebody with a Haynes manual for above mentioned car? You should have wires for coil, dizzy, alternator, and starter motor as well as the sensor wires.. Otherwise E-mail me and I will try and help you identify the wires, will be relatively easy with a testlamp or multimeter.
Brown/Yellow is Ignition (Charge) warning lamp to Field (small) terminal of alternator.
White/Black is Coil Negative to Contact Breaker points.
Regarding the "light grey": could it in fact be a dirty Coil Positive feed which is normally a plain white wire?
Or is it a dirty White/Slate in which case that is Coil Negative to Tacho?
HTH
Regards all
Richard
Rob, has Richards posting helped? If not I will give you a ring. what time is best?
Stu.
:0  hi stu , anytime after 7.30.
  once we' ve put rugrat to bed(daddys little princess) :zzz:
Haven't had time to check richards suggestion just yet.
 Anybody else got any ideas?
 :t-up:  :t-up:  :t-up:  :t-up:  :t-up:  :t-up:  :t-up:
Good or bad,
                    cheers rob
Rob.  I have e-mailed you a bitmap of the front part from the wiring diagram.  Did you receive it OK?
Neil Purdie
:D  :D  :D  :D  :D  :D
hi ,problem is now sorted,big thanks to all that posted :t-up:tried to turn her over lastnight,wouldnt budge,(car or wife)
:devil:  :devil:  :devil: now wheres that f***n fuel pump gone
cheers all,rob
:D  :D  :D  :D  :D  :D
