’02 2002 Westfield Megablade 10,000 Miles,
Black with carbon look front arches and rear arch protectors.
Registered new in 2002 with an 893cc engine so doesn’t need a cat to pass the MOT.
SEIW (Independent suspension all round)
Blueprinted AB Performance 919cc motor with approx 1000 miles since rebuild
Gear direction reversed (so it stays the same as with the 893 motor) using a custom rose jointed gear linkage (no play at all)
AB Performance intake system
Viscous type LSD with 338:1 ratio (recently built by road and race transmissions)
Mog carbon kevlar seats
Satin black powder coated aluminum panels
Dash, tunnel top and boot cover trimmed in black vinyl
Barnby Engineering mag 8 magnesium split rims (recently crack tested and rebuilt)
Yokohama A048 tyres, front 185/60/13 rear 205/60/13
Mychron 3 digidash and datalogger
Bailey morris centre bearing prop with TRT (no reverse)
Mocal thermostatic oil cooler with progold hoses
Standard Honda fuel pump (improved reliability)
Quick rack 2.2:1 ratio
Solid aluminum rack mounts
Terry Nightingale ‘Bike engine’ front anti roll bar
Front suspension nylon bushes, rear suspension rose jointed (NMB rose joints costing £50 each)
v8 bonnet
Westfield aeroscreen
Rac roll bar.
Custom Willans harnesses with aero twist buckle and aluminum adjusters
AP racing brake master cylinder
AP racing brake bias valve (cockpit adjustable)
SPA Alpha removable 270mm steering wheel (boss is SPA as well)
Momo pedals
Custom dash that covers gap below aeroscreen
Nomex honeycomb boot panel
LED rear lights
LED cluster fog light / brake light
Radiator fan override switch (and warning light)
Start button
SPA carbon rear view mirror integrated into aeroscreen (rock solid)
Carbon wing mirrors
Pagid RS14 front pads
Modified brake light switch with microswitch (more sensitive than pressure switch)
Fire extinguisher
Richbrook aluminum handbrake lever and gear knob.
I built this car in 2002 and have steadily upgraded it since. It’s now a really well rounded car that’s just at home on a track day as it is on the road.
12 Months mot and 6 months tax.
£8995
I'm located around Junction 10 of the M25.
Amyone interested should drop me a PM.
Scroll down for pics:
a very nice looking motor  ;)
Is it registered on a Q or 02 plate?
Do you also have the reverse box?
  • 2 weeks later...
hi, i e-mailed you a couple of weeks ago asking about your car and told you my budget. See my wanted add in the cars wanted. What is the condition of the bodywork? I really like your car and would like it very much.
wow
stunning motor........ if I was after a BEC  it would be this one
He's not logged in since the ad was posted, A mate of mine is also interested and has tried to contact the seller but has had no luck.
Just noticed this car also listed on ebay, maybe he could be contacted via ebay.
