Upper steering column
Now while I realise that a westfield isn't likely to be to most waterproof car in the world but when I fit the upper steering column in place then do I need to fit a seal around the column in case of a fire in the engine bay.  My gut feeling is that I need to ensure that the cockpit is as sealed as possible from the engine bay.  In which case what should I use? ???
Nope, just don't worry about it.
In the event of a fire, the *last* thing you'll be worrying about is flames getting past the bushes in the steering column !!
I agree, I would be the proverbial rat but is there a requirement for SVA?
I used a grommet similar o the ones Westfield supply for the wiring but more to keep out the wet.
Tomo
A bead of Sikaflex or silicon sealant will do the job
Russ
Thanks guys.  I suppose the first step is to make a well fitting hole in the plate.
I have just reached the same point building my car. I cut a 40mm Dia hole in the sheet, then cut a hole to fit the outer tube in a suitable sealing grommet, and fitted it. Nice and neat and simple. I can e-mail a picture if you want.
Regards
Richard
A picture would be much appreciated.
