The Ninj Posted October 22, 2009 Posted October 22, 2009 Can anyone shed some light on the wheelbase of a 2000 SEiW? The only figure I found was 3225mm. Figure for an SEi was 2335mm Is that correct? Do the Widebody cars have nearly a 1 metre longer wheelbase than the SEi? Sorry for the noob question, just trying to figure out if one will go down our driveway! Quote
stephenh Posted October 22, 2009 Posted October 22, 2009 I find it hard to believe that the wheelbase is as little as 2335mm on any Westfield. The wheels are very much at the 4 corners, and the car overall is IMSMC about 3600 or 3700mm (thereabouts) and I thought a narrow body was similar in length to a wide body, so I think the shorter figure you quote must be a misprint. Quote
Mark (smokey mow) Posted October 22, 2009 Posted October 22, 2009 Approximate dimensions of my SEIW Mazda SDV are: Width (Front) over wheels/tyres - 1480mm Track (Front) - 1290mm Width (Rear) over wheels/tyres - 1620mm Track (Rear) - 1430mm Maximum Width over body - 1640mm Wheelbase - 2325mm Overall Length - 3450mm Minimum Ground clearance - 70mm Quote
The Ninj Posted October 22, 2009 Author Posted October 22, 2009 Interesting, has anyone actually measured the wheelbase of a widebody? If the figures quoted for the Mazda sdv are correct then somethings not right somewhere? Quote
Mark (smokey mow) Posted October 22, 2009 Posted October 22, 2009 Interesting, has anyone actually measured the wheelbase of a widebody?If the figures quoted for the Mazda sdv are correct then somethings not right somewhere? Wheelbase and dimensions of a widebody should be within a few mm the same as the Mazda kit (which were measured off my own car). EDIT to say: curiousity has just got the better of me so I've been out to the garage for another measure and 2325mm is definately correct for my car. Quote
The Ninj Posted October 22, 2009 Author Posted October 22, 2009 I would think that too, but this is the only official looking document I've seen and it states the longer wb? http://www.prbaustralia.com.au/austglossy.pdf Quote
Mark (smokey mow) Posted October 22, 2009 Posted October 22, 2009 I would think that too, but this is the only official looking document I've seen and it states the longer wb? http://www.prbaustralia.com.au/austglossy.pdf Granted, it looks pretty official But looking at this logically for a moment if we have a wheelbase of 3255mm and an overall length of 3540mm both as given in the document then that gives a difference of only 315mm to account for the measurements from the centre of each axle to the front and rear overhangs. Assuming that each tyre will have a rolling radius of approx 275mm then mathematically a length of 3540 would be impossible for a 3255mm wheelbase. Here's a few sites that agree with my measurements http://www.supercars.net/cars/1893.html http://www.classicandperformancecar.com/front_w....see=790 http://www.flyinmiata.com/westfield/specs.php And plenty that don't http://westfield.devocht.com/index.php?section=7 http://www.buyacar.co.uk/westfield_mega_roadster/car_megabusa_7.jhtml http://www.hanksmegabusa.com/images/Megabusa-Specs.jpg Quote
melt Posted October 22, 2009 Posted October 22, 2009 Just looked at the spec in my 1800Q/Zetec SEIW build manual (printed in 2000), dimensions are as follows: Wheelbase 2346mm Track, front 1311mm Track, rear 1330mm Length, overall 3540mm Width, overall 1560mm Height, overall 1100mm HTH Mel Quote
The Ninj Posted October 22, 2009 Author Posted October 22, 2009 Thanks for checking this out guys! I'd measured up a plank of wood with the 3225mm WB and then stuck two drumsticks on either end at the so i got 160F/170Rmm ride height. Then took it to the top of our drive and "ran" it over the hump! It only just went over (it touched very slightly in the middle). If it is indeed the shorter measurement I should have no problems going down! My neighbours on the other hand now think I'm a proper lunatic. Lovely. Quote
Blatman Posted October 22, 2009 Posted October 22, 2009 QUOTE The only figure I found was 3225mm. Figure for an SEi was 2335mm Looks like a typo to me... Quote
pistonbroke Posted October 23, 2009 Posted October 23, 2009 The only figure I found was 3225mm. Figure for an SEi was 2335mm Looks like a typo to me... The typist probably works as an accountant for the Labour Gov Quote
Blatman Posted October 23, 2009 Posted October 23, 2009 Or Enron, or RBS, or LLoyds, or Lehmans, or [insert name of bank here]... Quote
