stewart pickles Posted August 21, 2009 Posted August 21, 2009 as it says on the tin type 9 long input shaft clutch nose,the bit that bolts to the front of the gearbox with 4 cap screws that the clutch centre bearing slides in and out on or anybody know how long it should be so i could weld a new bit on the end of the one i have (clutch nose for short input shaft)
Dave Posted August 21, 2009 Posted August 21, 2009 About £40 from quaife and its alloy not cast irony Dave
geothro Posted August 21, 2009 Posted August 21, 2009 i am rebuilding a box right now long type, also have a short type in bits. can puy the 2 together and check the difference in lenght if like. you can get an ali housing i think its about £60.
geothro Posted August 21, 2009 Posted August 21, 2009 the short housing placed on a flat surface 102mm long long first motion shaft housing 112mm long its 10mm longer if thats any helf to you
stewart pickles Posted August 22, 2009 Author Posted August 22, 2009 cheers guys,its a quaife box never thought about trying quaife
John Loudon - Sponsorship Liaison Posted August 23, 2009 Posted August 23, 2009 You'll get used to our Mr Pickles Matt
stewart pickles Posted August 25, 2009 Author Posted August 25, 2009 You'll get used to our Mr Pickles Matt do you want your new coat loudwun
Chris Elworthy Posted August 30, 2009 Posted August 30, 2009 I have one, 112mm long, Ford part number 839T 7050 AA PM me if you still need one I am in Northampton (it is spare as I converted to axial hydraulic clutch) Chris
