originalgeezer Posted August 18, 2009 Posted August 18, 2009 (Car is based in B63 Post Code Area) Dark Blue with Blue Interior and Yellow Trim Ducted Style V8 Nose New Black Surround Windscreen New Black BMS Engineering Roll Bar Hoop Carbon Look Cycle Wings Carbon Look Dash Board Carbon Look Arch Protectors Carbon Look Head Lights New Carbon Look Indicator Pods under Headlights New Clear Indicators and Repeaters Carbon Look Rear Light Surrounds 10k - 12 months MOT 4 x Previous Owners HPI Clear Thick File of Invoices Dating back to 2002 when sold by Terry Nightingale New Cat Motorsport Wide Track Front Suspension SPAX Dampers Northampton Motorsport Four Wheel Alignment 2009 Yokohama A539 Tyres 7x 16 Compo Motive MO Wheels Full Weather Gear – however cannot confirm the Hood will not fit due to the Roll Bar and new windscreen without hood fittings Engine Spec: Rolling Road Results at Northampton Motorsport 2009 2.0 Vauxhall XE Engine SBD Taper Throttle Bodies Kit SBD 2.0L Inlet Cam 11.40mm lift HYD.284 deg SBD Inlet Valves 33mm SBD 2.0L Exhaust Cam 11.03mm lift HYD.278 deg SBD Exhaust Valves 29mm SBD Single Valve Springs with Steel Caps SBD Vernier Pulleys SBD Big End Bearing Set SBD Heavy Duty Rod Bolts SBD Heavy Duty Main Cap Bolts SBD Head Bolts SBD Heavy Duty Flywheel Bolts SBD Heavy Duty Centre Crank Bolt SBD High Pressure Fuel Pump, High Pressure Regulator and Post Filter Bullet SBD Equivalent BOSCH 744 Injectors MBE 967E Engine Management New Cam Belt New Water Pump New Alternator New Fan Belt New Oil and Filter New Bottom End Gaskets Gearbox : BGH Type Nine Box with Long first Gear Folder thick of receipts and invoices Reason For Sale: Due to other commitments and another potential project the Westie will just end up sat in the garage for a good while which is a shame. The car is in good overall condition, many new items with some great specification along with a fresh MOT, oil service with camblet change, rolling road tune and four wheel alignment with corner weighting plus several new parts. Has some marks and wear as you would expect of a Westie of this age, but very clean and in good condition. As always there are always things you will want to change and upgrade which is custom to Westfield ownership. Could easily be used as Track Day, Hill Climb or Sprint Car with little work as the car is very quick or a very quick Sunday, Fun Day Car The car doesn’t have to be sold, just not worth keeping sitting in the garage doing nothing but if the right price isn’t met, then in the garage it will stay and as time and opportunity allow it may undergo more upgrades. To be clear the car will not be sold for less than the advertised price. £8500 Requires: Boot Box cover - on going project at this time More pictures by email due to size Email: originalgeezer@hotmail.co.uk Or PM me for further details and my number.
originalgeezer Posted August 18, 2009 Author Posted August 18, 2009 Pictures Added - more available by email.
originalgeezer Posted August 19, 2009 Author Posted August 19, 2009 Is this too cheap? Had a lot of emails today from the Piston Heads Advert. Plan was to give it four weeks to sell, then if didnt sell it would stay and I would continue its upgrades and my other plans would have to go on hold till another time. Fear I may haveunder priced it?
Cleggy the Spyder Man Posted August 19, 2009 Posted August 19, 2009 very nice spec for the money I would have thought - priced to sell - definately assuming it is as good as it looks in the photo's
perksy Posted August 19, 2009 Posted August 19, 2009 For the Spec this is Too cheap But should secure a quick sale *if* thats what your after I'd of started it around 10k and seen how it went You can always come Down, but it's abit awkward to go back up again
originalgeezer Posted August 19, 2009 Author Posted August 19, 2009 well, figured at the time of year and with the recession - even thought the price of some cars about you wouldnt think it, that it would be a fair price yes, it is as good as it looks, clean tidy and a good spec - spent a fair amount getting it this far! kind of hoped no one would be that interested - but the price is the price and I am not moving on it - so it may stick around still ! but by the emails, might not be....................
scott beeland Posted August 19, 2009 Posted August 19, 2009 Interior/ engine bay shots to boghouseblue@hotmail.com please
Nic Ayre Posted August 19, 2009 Posted August 19, 2009 I wish mine was that colour and spec, very nice, will have to buy another lottery ticket on Saturday.
originalgeezer Posted August 19, 2009 Author Posted August 19, 2009 Scott http://www.pistonheads.com/sales/1199120.htm Anymore required, shout up
scott beeland Posted August 19, 2009 Posted August 19, 2009 PM sent....but just a quick question. Has it always had an XE in it; or has it been retro fitted?
Jackv4 Posted August 20, 2009 Posted August 20, 2009 very nice this shouldnt hang around long good luck with the sale mate johny
originalgeezer Posted August 21, 2009 Author Posted August 21, 2009 Scott Had a look through the history last night, of which there is nothing to confirm it was built with a XE, but as far as I can tell, it was. All the Engine Build work ws done in 2005 with minimal mileage since. Hope this helps...... Johny Thank you for the comments, so far lots of emails and interest but that all so far....
whosthedaddy Posted August 21, 2009 Posted August 21, 2009 Very nice motor, don't fancy px it against mine?
originalgeezer Posted August 21, 2009 Author Posted August 21, 2009 No thank you...............if it sells I am looking at a different direction from westfield ownership, but if not, I am more than happy to keep what I have. Its a good car and pulls superbly and if kept may be seen being thrashed up a hill or two next year
originalgeezer Posted August 23, 2009 Author Posted August 23, 2009 Advert Updated How much hard work is this, the emails and calls.......but I am sure people don't read the advert So If I have missed anyone who has been in touch that I have not got in touch with, apologies.......
