Where can I find the engine number on my 1800 zetec?
I have found the number “46384114RKC” stamped on it, but is this it?
Thanks smayo :durr:
the engine number is stamped on a 'flat area' on the block just in front of the bellhousing on the exhaust side above the starter it will be something like "RQB" then "NS76124" or similar, I think the "RQB" bit says what model it was fitted to (Escort etc.) and the "NS" can tell you when it was made  - Ford Technical Support can provide the information once you quote the right number  :cool:
That's exactly where I found the number I quoted before, but it doesn't seem to be in the format that you describe.  Could it be the right number? or should I have a look again for another number? ???
And also just above the starter motor is another place they stamped it.
Paul
  • 3 weeks later...
Yes, the number ending in RKC is the engine number
The letters designate the engine configuration and model for emission purposes
