engine problems
have got a 2.o litre vauxhall engine for my westfield and am lookin to rebuild it before puttin it in. does anyone of a book or manual that could help me rebuild the engine. any advice owuld be much appreciated. cheers
16v or 8v?
Buzz :cool:
mike,
The only information that I've ever found is in the Haynes manual for the Astra GTE. Hope that this is of some help.
Si
Seconded, Haynes Manual is best for a how to strip and re-build. Dont forget many of the stress bearing bolts on this engine are angle tighten stetch bolts. This means they MUST be replaced on re-assembly. This includes:
Big Ends (replace with HD bolts)
Main Bearings
Head Bolts (two types depending on engine age)
Crank Pulley bolt
Flywheel Bolt
Cam pulley bolts
You can get parts reasonably from SBD or QED (see links section on website).
