g/box oil levels ?
how do i check oil levils on my cvh 1600 g/box 5 speed type 9
there is no inspection hole in the car itself any clues???
many thanks wayno ???
Jack it up crawl under from the passenger side there should be a plug in the side of the gear box use a 10mm allen key and remove the plug this is the level when the car is level top up untill it runs down your arm easier said then done.
Paul
