melf Posted December 15, 2001 Posted December 15, 2001 I am a recent owner of a Pre-Lit Westfield. The number of turns of the steering wheel Lock to Lock is about 2.6 revolutions. Is this a Quick Rack or not ? I believe the origanal rack/doner car was a Escort or Cortina MK1 if that helps ! Quote
Blatman Posted December 16, 2001 Posted December 16, 2001 The only way to know for sure is to have a look to see if you have lock stops fitted on the rack. If there are no lock stops you have a quick (but not very) rack. If you have lock stops, then you probably have a standard rack which has been modified to produce the number of turns lock to lock by limiting travel. It will probably have a crap turning circle too.......... Quote
CedricTheBrave Posted December 16, 2001 Posted December 16, 2001 Quick rack should be about 2.2 turns ?? Quote
ACW Posted December 16, 2001 Posted December 16, 2001 If it was a quick rack it would be the slowest of the quicker ratios (they are normally around 2.5 turns L2L. I suspect it is a normal rack with stops to prevent cycle wings hitting bodywork. Quote
melf Posted December 17, 2001 Author Posted December 17, 2001 Thanks for the info. I think it must be a standard rack although there are no obvious Lock stops, but the turning circle is poor, I thought this was a feature! Is it worth carring out a conversion to give a 2.2 L2L ? Does it make it sensible to drive off the track ? Any comments or thoughts appriciated. Thanks again for your comments, every day I am learning more about the car and the smile just gets better. Why didn't I buy one years ago ? Quote
Blatman Posted December 17, 2001 Posted December 17, 2001 My road car rack is about 1.9 turns lock to lock, and it's no problem at all. I would swap...............Bear in mind that the steering will be proportionately heavier as a result. Quote
