Hello,
I did a search before asking the question. I found some information but I would like a confirmation.
A friend of mine would like to change his dampers and springs on his Westfield SEIW (year 2000, zetec 2 liters, road use). He wants AVO shocks (nearly found them) but he doesn't know what to order for the springs.
Can someone tell me which springs he should order ?
Front : I have found 300 lbs... Is it correct ?
Rear : Range from 125 to 175 lbs... is it correct ?
Are there different lengths ?
Thank you
Ring someone like CAT if you want AVO, and they'll be able to advise on spring rates and lengths. My SEIW has 300lb front and 180lb rear, but I cant remember the lengths off hand.
Also try Procomp who do Protech shocks.
For my 2001 zetec SEiW I went for 300lbs fronts (but I was going to get 275lbs but they were out of stock), and 175lb rear springs. I think the standard is 200lbs but from searching on here it seems 150 ish is better.
My front (12ish") protech shocks have 7" long springs and the 14" rear shocks have 9" springs which gives some upward and downward adjustment of the spring seats, whereas my standard westfield supplied springs were at the bottom on the shock so ride height couldn't be lowered even if I wanted to.
Kev.
I've just been advised to go for 250F & 225R on my Zetec Westie.
depends what you use it for
160/180 is ok for the road but is too soft for the track
better with 225 or there abouts for track maybe even stiffer
also depends if you are a planning on going 2 up all the time best thing is to experiment imo
SH_T !
I think that I will also have to get new dampers too ! I tried to set the damping for the front dampers of my Westfield from 1998 (Spax) and the screw of the left damper turns without stopping (I don't feel the "clicks" as for the right one...). Has somebody had this symptom in the past ?
SPAX well known as being absolute sh*te. Mine were solid after 3 clicks and even set at the softest had no rebound at all.
Protech or AVO are great shocks for not too much £££.
Not too sure the best place for AVO's (Northampton Motorsport/PlaysKool?)these days but Procomp do the Protechs. www.procomp.co.uk
Yes, I think that I am also ripe for protech ;-)
I checked on the procomp site but found no email... My spoken english is worse than my written english, so I would like to write first... does someone has an email from procomp ?
EDIT : I just called Matt at Procomp. He was very helpful and friendly. Unfortunately, they don't sell dampers, they sell AND install them ! The problem is I don't live in UK  :down:   He kindly gave me the contact person at Protech for direct sale of protech shocks that should be "enough" for our use (road).
Protech direct are fine if you tell them they are for a Westy they will valve them correctly.
I have had good experience with them direct from the factory.
I received a quote from Protech for two sets of dampers (for my friend and for me now...  since I have a Spax damper that decided to let me down...).
They propose 12.5 inches front and 14 inches rear. Does it sounds good ?
For the springs, 300 front and 175 rear seems a good "compromis" for road use. What about the diameter  ? what is best : 1.9 or 2.25 inches ?
Thank you
Thank you
Spring diameter depends on the shock body - some are 1.9" diameter and others 2.25" so you will need to find this out.
Spring rates you've chosen are  :t-up:
It seems that protech shocks accept the two diameters. If there is no advantage to chhose one diameter rather than the other, I will choose the same diameter as the existing one.
I only have experience of the protech dampers that fit an elise and these were 1.9".
