stewart pickles Posted May 27, 2009 Posted May 27, 2009 afternoon.........will be back down your way soon to hit the pasty shops Quote
Bean Posted May 27, 2009 Posted May 27, 2009 See this thread LHD Beam Deflectors I fitted these to get through the MOT every year Buy Here There's a modification which involves drilling the alignment hole and twisting the lens apparently. Quote
Rory's Dad Posted May 27, 2009 Posted May 27, 2009 There's a modification which involves drilling the alignment hole and twisting the lens apparently. That's correct - they need a new slot cutting so that the near side kicks up and the offside drops down instead of being level. There's a guy on Locost Builders who sells them (Furyosi or something) and he will be able to advise. Rory's Dad Quote
LocoR1 Posted May 27, 2009 Posted May 27, 2009 Here you go his user name is "russbost" if you look at the link below to his site and scroll down to the lights the mod needed is in the description http://www.furorecars.co.uk/forsale.php Quote
speedy jon Posted May 27, 2009 Author Posted May 27, 2009 i took it back to work this afternoon and took the screw out of the bottom and tilted the lens when he wasnt looking and got it spot on. i think he was having a power trip tbh cos a few of the other lads was wondering why he failed it on that. oh well next time he asks me to lent one of my tools he can go elsewere. cheers for you help guys Jon Quote
Gadget Posted May 27, 2009 Posted May 27, 2009 My local MOT man indeed pointed it out that the dip pattern was wrong, but then said 'You race in the speed series don't you? You need to put some tape on the glass to hold it together if it breaks; use the beam setter and put the tape across the lens to hide the Kick up so that the beam is flat. I can do your ticket then.' Job sorted and much cheaper than beam deflectors (He even gave me the tape!) Quote
dhutch Posted May 27, 2009 Posted May 27, 2009 Mine passed fine, he looks at them both twice, but didnt mention a thing. - And I had alined them myself, up against next doors front wall, the night before. Quote
DPM Posted May 27, 2009 Posted May 27, 2009 I had the same problem on my old Westfield with these lights. The examinar stuck two bits of electricians tape over each headlights to stop the beam pattern going to right, then pased it. (as you see when driving abroard) I took the tape off affter that with no issues. Quote
steve mahon Posted May 27, 2009 Posted May 27, 2009 Also had the same problem. MOT guy just twisted the lens round slightly. Sorted. Quote
Matt Seabrook Posted May 27, 2009 Posted May 27, 2009 afternoon.........will be back down your way soon to hit the pasty shops Cool good old Cornish fast food better than McDonalds any day. Fancey a trip to route 38 Quote
Bean Posted May 28, 2009 Posted May 28, 2009 Here you go his user name is "russbost" if you look at the link below to his site and scroll down to the lights the mod needed is in the description http://www.furorecars.co.uk/forsale.php Awesome, I'll do the mod myself before MOT time. The beam deflectors aren't a great permanent solution, they fade rather quickly in the sun. Quote
housebeautician Posted May 28, 2009 Posted May 28, 2009 my fella said dont drive at night.Problem solved.have an mot. Quote
Bean Posted May 28, 2009 Posted May 28, 2009 my fella said dont drive at night.Problem solved.have an mot. So you've got a daytime only MOT? What happens if you get stuck somewhere and it's dark? Quote
brianm Posted May 29, 2009 Posted May 29, 2009 My old car had streetfighter bike lamps from M&P, up and down dip only, My regular tester asked, "Don't you get flashed at night?" "Don't know, it's never been out in the dark", was the reply. PASS Quote
