As some people may know I after only one session at Abingdon I went out for the second only to hear a knocking noise. I imidiatly came in and was advised it sounded like my big end. The engine was not run again to save any further damage. On inspection it appears oil scavange caused the crank bearing cups to be damaged so would need some bottom end work.
So, I am either going to strip for parts that people would like... let me know what you want and how much you are offering.
OR, you can make me an offer for the whole engine, you can either get the crank balanced and re-ground and fit new bearing cups or fit replacements.
The engine was fitted to a factory built Westfeild in 96 so would have only been 1 year old (phase 2 silver top started in 95) it then did 14,000 miles and was looked after well by Northampton Motorsport until I damaged it  :bangshead:  It started life at a Westfield broucher value of 175bhp and I have a dyno graph to show 165bhp (at the fly) which is much more accurate.
Includes, Cams, Westfield shortend sump, Flywheel, Clutch, theromstat, etc, etc.
http://img.photobucket.com/albums....874.jpg
Separatly, I have a Westfield engine mount for the intake site.
I also have the brand new ford exhaust manifold, intake system (including injectors, fuel rail, butterfly), and belt covers from a 2.0 Black top if anyone is interested.
Put the ford original parts on Ebay.
I have sold a few of the exhaust manifolds (don't ask where they came from) and got around £40 each for them.
I would be interested in the sump if you split the engine.
Mal
Hi
can I buy the lot.
                          07747147175
I would like the exhaust manifold please Tim if I'm not too late!
Hi
can I buy the lot.
Yes, see you tonight.
Yes, Dale (WESTMETAL) is only after the sivler top so the black top manifold is available. You have a PM  :t-up:
  • 4 weeks later...
Here are a few pictures I have taken but I need to clean of the bits and take propper ones' for ebay but before I do let me know if anyone wants anything...
Silver top inlet side engine mount: £20 including postage within UK
Various Silcone hoses (32mm ID, 15mm ID, 8mm ID)
Standard Ford Blacktop exhaust manifold: £40 including postage within UK
Spark leads and pack: SOLD
Whole silver top engine (excluding sump and cam cover): SOLD
Westfeild Zetec altinator mount: SOLD
Westfield water pipes (top rad and heater U): SOLD
Zetec overcooling resolution hose (custom made part): SOLD
Engine top (cam cover): including silver allan bolt kit SOLD
Standard Ford Blacktop intake: SOLD
Sump: SOLD
Brand New Ford 2 part sump from 2.0 black top zetec: Thrown in the bin.
Sump in need of a bit of a clean:
/Westfield/IMGP2990.jpg[/img]
Silvertop sump?
Is the inlet manifold assembly still available, and if so how much do you want for it?
Mal
Silvertop sump?
Yes, that is correct.
Updated with sold parts and some prices.
  • 2 weeks later...
Interested in the Engine top (cam cover), were you from or any idea how much for delivery?
whats left and how much  ??
Sorry already sold to another member.
