dombanks Posted April 26, 2009 Posted April 26, 2009 Anyone had any experience with tyre weld or similar stuff? How bad a puncture will it sort out? Quote
Asterix Posted April 26, 2009 Posted April 26, 2009 Sorts on-purpose oik-placed fence bolts in two different places. Managed to inflate Zafira tyre to enough psi to get to tyre place (15 miles away along minor roads and dual carriageway). However, if you use tyre weld, then a problem that could've been patch-repaired will not be handled by kwik-fit et al (and you should warn them that you've used it before the tyre is removed). Quote
Norman Verona Posted April 26, 2009 Posted April 26, 2009 I used a can on one of the front tractor wheels last rear. Just had a new inner tube so can't complain. Some cars come with a can of the stuff instead of a spare wheel - Elise is an example. Quote
perksy Posted April 26, 2009 Posted April 26, 2009 *If* you use the Tyreweld take the empty can with you when you attempt to get it repaired Some places will repair it aslong as they know what you've used to carry out the temporary repair with *Think* Holts Tyreweld is ok'd by the Tyre Retailers But stand to be corrected on that one Quote
spence Posted April 26, 2009 Posted April 26, 2009 There is a solution you can put in your tyres and you'll never get a puncture, can drive over nails etc and nothing happens. Got a bottle of it at work but can't remember what it's called atm. Will post it up tomorrow if i remember. Works really well and haven't had a puncture since. Quote
pistonbroke Posted April 26, 2009 Posted April 26, 2009 There is a solution you can put in your tyres and you'll never get a puncture, can drive over nails etc and nothing happens. Got a bottle of it at work but can't remember what it's called atm. Will post it up tomorrow if i remember. Works really well and haven't had a puncture since. Concrete ? Quote
spence Posted April 26, 2009 Posted April 26, 2009 Same sort of thing as this, have a quick look at the vid. http://www.tyreprotector.com/ Quote
dhutch Posted April 26, 2009 Posted April 26, 2009 I often carry one in the car (i think you have to dont you, if you dont have a spare, else its a requirment of my breakdown cover or something) however i would always be dubious of using it. - What sort of mess does it make of the wheel, if nothing else? Daniel Quote
Blacknblue Posted April 27, 2009 Posted April 27, 2009 I have used these on some off-road tyres, works fine on nail / screw sized punctures. Not meant as a permanent repair on road tyres but as an emergence get you home type solution it works well. Obviously you need a pump too!! But at least no worries about gunge in the tyre when you come to have it replaced. Quote
dombanks Posted April 27, 2009 Author Posted April 27, 2009 thanks, ive never seen the crafty plugger before, im not sure anything would have helped. the tyre has no nails/tears but would not even attempt to pump up. i guess i must've knowcked it off the rim or summat? but while i was waiting for a spare to be fetched i got to thinking about what to do if it was just a puncture. Quote
spence Posted April 29, 2009 Posted April 29, 2009 Sorry it took a couple of days but this is the stuff we use in our work vans. http://www.netparts.co.uk/store....s_id=49 You put it in before you get a puncture although it can be used on a punctured tyre. It won't inflat it and will need to be repaired at a later time. Half of a 16fl.oz. bottle should do a small tyre. So £20 should cover one small car. Not had a puncture with it even after driving on building sites. When i've had a tyre change there isn't really a lot of mess on the wheel either. Haven't tried it in the westy yet but will do later. Hope this helps. Quote
samcooke Posted April 29, 2009 Posted April 29, 2009 If Blatman still liked us, he'd be along now singing the praises of the home repair kits like crafty plugger and telling us how he's done 200mph on bikes with 10 repairs in the rear tyre. No experience myself, but I've always found quoting the man is a good way to make it look like you know what you're on about. Quote
