Number plates on nose cone
How have those of you who don't have a stick-on number plate fasten it to the nose cone?
Custom brackets, plastic rivet through lower nose cone lip? etc etc
Chris
Build site
:cool: I’ve not had a front number plate for decade; although I do wire one on the grill for MOT purposes only. Cop’s don’t seem to care and speed traps that take pictures of the front of the car are useless -  which has saved me many a penalty point over the years.
When I shattered my front numberplate for the 'Nth' time, I took it off and carefully peeled the perspex face off ( it was in 3-4 pieces ! ) and then had the reflective paper backing laminated in clear pvc before screwing it back.
Now it simply bends backwards when it comes in contact with any  obstruction and is probably  more aerodynamic at speed. :)
Problem solved.
I have a aluminium plate behind the regestration plate as every time I went into the garage I caught the bl**** thing and cracked it
Go without one man!! I carry a "replacement for the broken one officer :devil:  :cool: " in the car
Stainless steel hinges for glass display cabinet doors  :t-up:
folds up out of sight over 25mph  :0
will be at donny on sat for inspection. :cool:
yeah right, I bet they nicked you every time after recognising that mask of yours :D
Hello, hello, hello. Rules for the display of number plates are set out in law and breaking that law could mean:
A fine of up to £1,000
The registration mark may be WITHDRAWN
The vehicle may FAIL the MOT test
:devil: Now where’s my riot baton…
Believe it or not, Westfield Sportscars can supply you with some custom front numberplate brackets :D
Chris,
I had the same problem with my'n and so made up a plastic one, see enclosed pics. This is vac formed in the same way we make the Carbon Effect stone guards, rear lights and front wings. But at the moment only using a temporary tool. If there is enough interest then I will make a batch.
Front Numberplate Plastic fixing -side view
Using this gives an extra 55mm clearance.
Front Number Plate showing lifted up by 55mm
Nick
With a large Hammer! :durr:
Or a Hilti gun  :durr:  :D  :)  :p  :devil:
It would seem that whilst the five fingered widow knows there is a law, she doesn't know what it is. So.............
Front number plates must be mounted on the "first suitable vertical surface" of the front of the car. A Westfield doesn't have a suitable vertical surface (the lower "lip" of the nose cone is unsuitable as it is too small, and too close to the ground.........), and many MOT testers have agreed with me.........
The rules for withdrawal of an index number are only applied if you alter it's appearance to look different to what it should, and do NOT apply to the "where you fix the plate" question. Get nicked 3 times with an altered plate, and the police/magistrates/DVLA have the option to withdraw it.
And I bet The 5FW looks a lot younger than many folks around here  :p  :D  :devil:
Mind that ain't too difficult is it  :blush:  :D  :devil:  :D
