Megasquirt and MBE Ignition ECU + Looms
I have for sale
1 x MBE 956 ( I think) ignition module and loom.
1 x Megasquirt I running MSNS extra 024 code + loom for vauxhall C20XE.
Apparently this MSNS Extra code can run the coils also but was not setup to do so.
The ignition map on the MBE is a Stock map for weber 45 carbs and distributorless setup. The megasquirt was added after upgrading to Jenvey 45mm throttle bodies so I guess the mapping is fueled to suit.
When on the car it was kicking out 178HP and 168lb/ft of torque. I have the rolling road print out with the power and torque curves + AFR
Offers ?
Ben
I am interested but don't know what it is worth.I haven't been looking as I am just starting my kit. How much are you looking for?
PM'd
Ivor R
Hi,
Further info V2.2 MS I board. I am after £100 to £150 for the MS I.
Ben
